Part # ?
Old May 30, 2013 | 08:12 AM
Blackwaterforge's Avatar
Blackwaterforge
Part # ?
Does anyone know the part # for a z bar pivot stud that threads into a 300 6 cylinder engine?
Truck is a 66.
Engine is a 74.
Thank You!
Old May 30, 2013 | 10:27 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Is that a '66 2WD or 4WD? Does it have an NP435 transmission?
If you have the books it is in the Illustrated Section 75 pages 25 (2WD) and 26 (4WD)
Base number is 7A535 for the 6 cyl engine
If it's a 2WD then I'd think C5TZ-7A535-A - Pivot, Clutch Release Equilizer Engine Mounting - $29.70 at NOS Ltd
http://www.nospartsltd.com/product-p/C5TZ7A535A.htm
Of course, that's all 1966. Not sure if the '74 motor changes things or not.
Old May 30, 2013 | 10:54 AM
Blackwaterforge
66 F-250 2 wheel drive Borg warner T-18 4-speed.
300 6 cylinder engine.
Old May 30, 2013 | 11:59 AM
daveengelson's Avatar
daveengelson
Jumping into this thread to see if a member comes up with the P/N. Currently in the infancy stage of learning how to use the Ford Master Catalog and could not find a part number for the item.
According to 240/300 diag. the came up with a base # 7A531 but could not fine the item in the Text section???
Suggest check w/ local Ford dealer, or part supplier, believe the 6cyl. ball is same thru 77. If not; checked 2-3 Ford Part supplier's, according to their online catalog they only offer the pivot ball for the V8., specifically the 302. Suggest contact one of the more reputable suppliers and inquire, can't imagine they would not have the 6cyl ball. Did find 1 supplier who list the 6cyl. ball and that is John's Fun100 out of SoCal but can expect to wait at least 2 weeks to receive the item.
Old May 30, 2013 | 12:20 PM
Blackwaterforge
Thanks Dave!
Old May 30, 2013 | 12:51 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I was updating my post as I looked things up. Read it again and it has the part number and one source for the part.
Old May 30, 2013 | 12:58 PM
TA455HO's Avatar
TA455HO
Lead Gopher
7A531 is only showing as applicable for the E series Econoline models so you must have started with the wrong illustration. Section 75 pages 25 and 26 are what you should be looking at as far as I know for the F series.
Old May 31, 2013 | 01:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-7A535-A .. Clutch Release Equalizer Bar Pivot-Engine Side / Obsolete
1965/74 F100/350 240/300 I-6 / 1975/76 F100/350 300 I-6 / 1977 F100/350 300 I-6 before serial number Z00,001.
1969/74 Econoline 240/300 I-6 / 1975/76 Econoline 300 I-6 / 1977 Econoline 300 I-6 before serial number Z00,001.
240 cancelled at the end of the 1974 model run.
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
NOS ONLY in San Jose CA has ONE = 800-667-6659.
B & B AUTO PARTS in Bronx NY has ONE = 718-597-3383.
Old May 31, 2013 | 05:23 AM
daveengelson
Thank you, went back and retraced my steps and see where I started off with the wrong illustration and although it took me 30 min's to come up with the wrong answer now believe I have little better understanding as to how to use the catalog; as NumbersDummy mentioned in his 'Ford Master Catalog break down' it's a matter of counting 1,2,3. Goes to show some times can teach ole timer's new tricks.
Old May 31, 2013 | 07:10 AM
Blackwaterforge
Thanks Guys!
Trucker95
Apr 28, 2015 11:58 PM
Shwan_89HD
Jun 7, 2013 08:38 PM
Pishnook
Feb 12, 2012 10:09 PM
Downtrodden
Jan 26, 2004 11:44 AM
gunner
Dec 29, 1999 09:14 PM
