Injector Pump and Timing Troubles
Old May 29, 2013 | 09:03 PM
ALedbetter1's Avatar
ALedbetter1
I removed the IP to fix the gasket at the bottom of the IP housing adapter. after I got it put back together I realized my scribe marks had been messed up. I got it back as close as I could to where it was originally. It took for ever to start and when it did it ran terrible and put out a massive white cloud of smoke. I tried turning the pump clockwise like a distributor on a gasser but broke the elbow that come out the top of the IP for the return line........... So my two questions are was I on the right track turning the pump? And do I got to have this elbow with what looks like a 1 way valve on the end or can I use a regular brass elbow with out the valve?
Old May 29, 2013 | 09:08 PM
ALedbetter1
Scratch the whole elbow thing after looking at it some more the elbow and valve are separate things and part of the elbow broke off in the valve with a bit sticking out. Now to figure out how to get it out.
Old May 29, 2013 | 09:50 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
If you didn't mesh the gears correctly you will never get it to run right. Checkout the link at the top of the main page.
Here it is.
https://www.ford-trucks.com/forums/1...alignment.html
Good luck,
Mac.
Old Jun 10, 2013 | 04:24 PM
ALedbetter1
Thanks I found the marks and got it back in time and it took the mpg from 15 up to 25 so it looks like the problem is pretty well cured.
19887.3IDI
27
Dec 7, 2015 12:22 AM
wabashofutah
Feb 15, 2014 08:19 AM
axel 56
Jun 14, 2011 09:34 PM
Kirkus05
Apr 29, 2006 08:54 AM
88-F250
Jul 25, 2005 05:38 AM
