7.3 knock issue or??
Old May 30, 2013 | 11:04 AM
20powerstroke02's Avatar
20powerstroke02
The front one was wet already and barely tightened again a bad gasket. But I can't say it wa wet due to a bad gasket. When I removed the oil cooler maybe I splashed coolant on the block surface you know? Rebuilt the oil cooler found bad o rings. Out it back in filled resivoir and let it sit for 48 hours or so and the water level never changed. Pulled the injectors and found bad o rings so I re did them all. Now I have been fighting with getting the left over water out and let me show you what I did to get most of it out.
Old May 30, 2013 | 11:08 AM
20powerstroke02
I just went out to try and start it but most of my oil from the hpop is in the pan.... I have to charge the battery again but I have a few things to show you guys.
Old May 30, 2013 | 11:12 AM
20powerstroke02
The oil pressure sensor for the dah is on top of the hpop resivoir right? Mine oil gauge works only after I crank it for a while.... Almost like there's no oil there and I have to pump it up
Old May 30, 2013 | 11:19 AM
20powerstroke02
That's how I got all that nasty crap out of the motor. Both plugs were off when I did this yes there was oil in the engine I did this until clean oil came out.
Old May 30, 2013 | 11:32 AM
20powerstroke02
Sorry for all the typos guys this iPhone lags bad if I text anything over 5 words....
Shawn.54
Oct 8, 2018 04:47 PM
Elijah Doub
Jan 13, 2017 08:12 PM
Fordx4jake
Nov 3, 2014 12:59 PM
heathrunkles
Jan 18, 2012 04:39 PM
chrisjrosenbohm
Mar 25, 2010 08:42 PM
