cab lights
Old May 29, 2013 | 10:52 AM
srisher's Avatar
srisher
cab lights
Hello all,
I was wondering if any knew if these trucks had the option for cab lights (Im sure they were). I never seen any installed on one of these and I like the look and have been considering putting cab lights on my 65.
Any input would be great
Thanks
Old May 29, 2013 | 11:41 AM
schoo's Avatar
schoo
cab lights? In mine(64') their is a wire( think it is black the red one is for gas thank) from the light switch up to inside of roof that was for inside cab light?
I don't think any on the door switch was made
Old May 29, 2013 | 11:55 AM
srisher's Avatar
srisher
Im sorry I meant outside lights that go on the top of the cab
Old May 29, 2013 | 12:14 PM
schoo's Avatar
schoo
then run another wire to same place or splice in to the wire
how much light do you want? if spot light bigger wire new switch
Old May 29, 2013 | 12:18 PM
srisher's Avatar
srisher
they amber in color in most cases there are five (5) of them
Old May 29, 2013 | 12:31 PM
srisher's Avatar
srisher
I talking about lights similar to the ones on top of the cab on this truck
Old May 29, 2013 | 02:31 PM
fordpt's Avatar
fordpt
Icc 2 clearance and 3 center marker lights. Ford total Performance ACCESSORIES for 1966 lists C2TZ 15442-B $4.95.
Old May 29, 2013 | 02:47 PM
srisher's Avatar
srisher
thanks for the info fordpt,
Old May 30, 2013 | 02:47 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's the gaskets for the clearance lights.
http://www.ebay.com/itm/NOS-Cab-Light-Gaskets-1961-1965-1966-1972-Ford-Truck-F100-F250-F350-4x4-Bronco-/140972515141?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d29ddf45&vxp=mtr
Old May 31, 2013 | 11:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Icc 2 clearance and 3 center marker lights. Ford total Performance ACCESSORIES for 1966 lists C2TZ-15442-B
Be aware that FoMoCo is infamous for replacing 10's of 1000's of part numbers EVERY YEAR!
DOTZ-15442-A .. (replaced B9T-15442-A, C1TE-15442-A, B & C, C2TZ-15442-A, C2TZ-15442-B, C8TZ-15442-A) .. Roof Mounted Clearance Lamp Assy. (includes base/lens/lens gasket) ~ Amber ~ Tear Drop shaped / Obsolete
Applications: 1959/75 all trucks (except School Bus & P Series Parcel Delivery) / 1976 all trucks (except School Bus & P Series Parcel Delivery) before serial number A25,001.
Over 50 available NOS
Post 9 = DOTZ-15A402-A (replaced C2TZ-15A402-A) .. Gasket-Marker Lamp Lens ~ Use with roof mounted clearance lamps. Same applications as above / Obsolete
Over 70 available NOS
Old May 31, 2013 | 11:08 AM
srisher's Avatar
srisher
Thanks ND,
Good Info to have
ho_shi
Mar 29, 2013 10:46 AM
1972RedNeck
15
Nov 14, 2011 11:59 AM
Bluebronco85
Oct 25, 2009 10:16 PM
87white250
Jun 23, 2008 07:08 AM
royharper
Feb 20, 2008 06:40 PM
