random question...
Old Jun 22, 2008 | 10:49 PM
87white250's Avatar
87white250
random question...
i have an 87 f250 and I got some oem cab lights for it that im gonna install... .could someone briefly walk me thru how to do it, and also this is the biggest thing could someone measure where they are or post A pic or somethin so i have something to go off of on where to start.. thanks alot
Old Jun 23, 2008 | 07:07 AM
cbslayer's Avatar
cbslayer
i put a set of aftermarket cab lights on my 87 f150 but it had the aftermarket cab visor on it so i mounted to it i can help with basics this is what i did but it may not work for you if your mounting to roof of cab i measured the distance from where i wanted the 2 lights on the ends oposite each other then split the diffrence cut measurement in half thats where i put center light then did the same for center light and end lights to mount the other 2 lights i drilled hole through roof for hot wire as the lights on cab will or should ground themselves not sure what lights you have connect all hot wires and i ran wire to light switchfound the parklight wire with test light and hooked them up just becarefull not to short out wiring fuse should protect it but you never know you may want to hook up a toggle switch with in line fuse your gonna have to take out the roof liner and drill holes through your roof i do not envey you use silicone on all holes
Old Jun 23, 2008 | 07:08 AM
cbslayer's Avatar
cbslayer
oh take your roof liner out first to see any problems first before drilling any holes like channels wires etc....
