ok, got an 03 f250. does not have factory cab lights. i really wish it did. just wondering if the wires are already run under my headliner for them from the factory or if i would have to wire the whole deal to add them. thanks
Hey man, I believe that it's pre-wired, but I'm not entirely sure on that. I still need to get around to ordering a shop manual with wiring diagrams - but I'm pretty sure someone else on here will chime in. There is a thread on it somewhere. I do remember several people finding out that from inside the cab - you can see the spots where the lights are supposed to be mounted. (I forget if it was a cut out, or pop out spot that's already pressed into the sheet metal, but it'll mean dropping the headliner either way.)
There is a plug in the passneger side kick panel that is run for cab lights. When ever you order your kit make sure that you state whether you have the overhead console with display or not, because the wiring harness that you get will be a factory ford component.
If you dont have the lights, you dont have the harness. You can easily make one up or get one from ford. I got my lights and harness from them all in one shot. Like Austin said, get the right harness. The overhead console and running lights use the same plug.
