Rear wiper relay question
Old May 23, 2013 | 06:40 PM
vdrowley's Avatar
vdrowley
My rear wiper is malfunctioning, it spins around with no resistance and sits askew, and since I've only used it 4 or 5 times in 13 years I don't really care if it ever works again. While charging my dead battery I heard a clicking sound from the power distribution box. I discovered that the wiper relays were the culprits, happily clicking away in unison. I've pulled them and I'm considering leaving them out.
So the question is, can I leave the rear wiper relays out with no repercussions? My gut feeling is no wiper, no relay, no,problem.
Thanks for your replies.
Vince
2000 Explorer
2008 E150 fire engine red
a small heard of Vespas
Old May 23, 2013 | 06:58 PM
oneowner83's Avatar
oneowner83
I'm with you on this, can't imagine a problem. My 2000 rear wiper has NEVER worked, and I never cared either.
Old May 24, 2013 | 10:42 AM
vdrowley's Avatar
vdrowley
It's always the simple answers. I couldn't figure out why the relays would sit there and click. Perhaps if I turn off the wiper switch!
Yes, the wiper switch was in the on position and that's why the relays were trying to, well, "relay". Not going to reinstall the relays so I don't have a battery run down again.
Old May 24, 2013 | 03:31 PM
meborder's Avatar
meborder
sounds like a plan.
electrically speaking, there is no difference between removing the relay or fuse and never turning the switch on. either way the motor never runs.
i just never touch my switch ... darn rear wipers anyway.
Old May 27, 2013 | 10:34 PM
shorod's Avatar
shorod
I confirmed from the factory wiring diagram that those relays are only for the rear wiper. No other circuits should be impacted if they are removed.
-Rod
JavaDaddy
21
May 6, 2019 04:34 PM
snowsurfusa
May 14, 2013 10:31 PM
Blueman2
Nov 26, 2011 12:17 PM
dubbz
1983 - 2012 Ranger & B-Series
Dec 23, 2007 08:38 AM
84stallion
Jul 29, 2003 04:09 AM
