winshield wiper
Old Dec 19, 2007 | 03:40 PM
dubbz's Avatar
dubbz
winshield wiper
My 1998 Mazda B2500 truck, I turned the wipers on and they went straight up and stopped. The fuse in the drivers side compartment was ok, I could hear a relay clicking in the power distrubution box but I can"t figure out which relay it could be. Anybody have a clue which it might be or had a similar problem? Thanks for any help.
Old Dec 19, 2007 | 03:51 PM
dubbz's Avatar
dubbz
I forgot to say I live in Pennsylvania and the wipers were iced over. I cleaned off the ice and that"s when they went vertical and stayed there.
Old Dec 19, 2007 | 06:09 PM
rangergolfer's Avatar
rangergolfer
go to this tread, i think it will answer your question.https://www.ford-trucks.com/forums/6...r-problem.html
Old Dec 20, 2007 | 09:25 AM
michigan66's Avatar
michigan66
Since you hear the relay clicking, get a helper to activate the wipers and feel along the relays. The one that vibrates is the one you want.
Old Dec 20, 2007 | 09:32 AM
charliec's Avatar
charliec
Just had the same this w/ MY exploder last weekend after the Ice hit SE NY, It looks like I got a chunk of ice under the screening stopping the arms from moving, Mine looks like it will be OK after it thawed a bit over this way,
Old Dec 20, 2007 | 10:22 AM
sfcwoodret's Avatar
sfcwoodret
Also check and make sure nothing fell down into the wiper arm assembly and is blocking the movement.
Old Dec 23, 2007 | 08:38 AM
dubbz's Avatar
dubbz
Sure enough, full of ice under the screen. Thanks to all for their help!
