2002 Expedition Wiper malfunctions help
Old May 6, 2013 | 11:31 AM
snowsurfusa's Avatar
snowsurfusa
I have a 2002 Expedition and ocassionally for a while the rear wiper will intermitently go on and off and every once in a while the front will do the same now. All of the switches are in the off position. Any thoughts on what I need to replace. Would it just be the wiper arm/switch or could it be something else?
Old May 6, 2013 | 03:11 PM
alloro's Avatar
alloro
Since both the front and rear are acting up I would think you're correct in blaming the switch.
Old May 10, 2013 | 10:58 AM
snowsurfusa
Still Having issues
So I got a new switch for the steering column and the problem continues with the rear wiper going on and off on it's own. Any thoughts out there as to what else I can try to fix the problem?
thanks,
Old May 10, 2013 | 11:45 AM
alloro's Avatar
alloro
Is the front wiper issue now solved because of the new switch?
In the under hood fuse box there is a rear wiper up #209 and a rear wiper down #205 relay. If the spring is broken in the rear wiper up relay then any bounce could trigger the movement of the rear wiper.
Old May 10, 2013 | 01:08 PM
snowsurfusa
still having problems
no, the front one is still going off as well.
Old May 10, 2013 | 10:22 PM
alloro's Avatar
alloro
Oh boy, this is going to be one of those strange ones.
Old May 14, 2013 | 06:57 PM
snowsurfusa
GEM Module question
I have been told that my GEM module is bad and needs to be replaced. I have had a couple of people tell me that it isn't worth buying an aftermarket Module as they just don't work, even though they are half the price.
I have also been told that this is not a do it yourself project as the module needs to be programmed which needs to be done by dealer or independent shop.
Can someone please advise if this it the case?
thanks,
Old May 14, 2013 | 10:31 PM
alloro's Avatar
alloro
For $50 or so you can get a used one off eBay. Just make sure the numbers match exactly.
985crabs
15
Mar 24, 2015 03:08 PM
Tparkin99
Electrical Systems/Wiring
Jul 4, 2014 03:00 PM
smgval
Feb 18, 2006 04:19 PM
RLFulton
Dec 3, 2003 07:37 PM
