when towing my trailer 5000# the EOT has been running about 15* higher than the ECT. After a cold soak they are the same. I ordered a oil cooler from Tousley , but now I need to know where to get the coolant flush, and what kind to get.
Thanks for your help Ron
I used Restore and Restore Plus. They are Cummings products, so if you have a dealer near you they will have it. Make sure you have lots of water to flush all that out after you do it.
If you have an 05-07 you may want to also replace the STC fitting on the HPOP while you are in there.
Depending on where you live you may also want to do an upgrade to the EGR system.
Just so you know the 15 degree rule is for running down the highway @65 mph unloaded after everything is up to temp.
Josh: you made that point in another thread some time back and I just have to add a supporting couple words:
Now that I've done more extensive data logging and tried doing both types of tests under several conditions. I really cannot see how a Ford tech doing the WOT test (particularly as vague as it's written) can get any kind of repeatable or reliable results. On the other hand, steady state cruising seems to produce much more stable and repeatable data (deltas).
I likely changed out an oil cooler that I'm doubting was bad for the updated one with one more row. My deltas are almost the same!
