Help! ECT vs EOT
Old Oct 9, 2010 | 09:15 PM
jims406rs's Avatar
jims406rs
Help! ECT vs EOT
Just got done doing HG's, Studs, EGR delete, oil cooler on my 04. I also did a coolant flush and added a coolant filter. Just got my new edge insight CTS installed and now I have some questions. I have observed the following readings while running 70 mph with about 70 to 75 degree outside temp with no load.
ECT 192-194
EOT 208-210
most of the time I had about 14-16 degree difference
Today I observed these readings while running 70 mph in 85 degree temp while towing a 16' trailer with 2 atv's on it
ECT 192-210
EOT 216-230
most of the time 18-20 degrees difference with 26 degrees once
Why am I seeing so much of a difference in temps between oil and coolant. I was expecting 6-10 degrees. What could be the problem?
Old Oct 9, 2010 | 09:51 PM
ljutic ss's Avatar
ljutic ss
I can't answer why your oil temps are that high empty, but I will give you my readings doing 70 mph on level road this past Thurs. This was 1 hour of driving and the temp was 75 that day, ECT 192-193 EOT 198-199 truck was empty.
Old Oct 9, 2010 | 10:13 PM
bismic's Avatar
bismic
Did you use VC-9 for the flush?
Old Oct 9, 2010 | 10:39 PM
jims406rs's Avatar
jims406rs
yes, did use vc-9. oil cooler and egr cooler had already been previously replaced recently so even with the vc-9 it was already pretty clean.
Old Oct 9, 2010 | 11:30 PM
1973dieselhighboy's Avatar
1973dieselhighboy
you need a new oil cooler ford spec is no more then a 15degree max diffence and we test them running them up a 2-3 mile hill wide open to try and make them fail i would put a cooler in it cause that is way to big of a diffence should be about 5 to 10 degrees tops and thats running it hard.
Old Oct 9, 2010 | 11:34 PM
jims406rs's Avatar
jims406rs
I just put a new cooler in it as stated in my first post. Thats why I dont understand the temp diff.
Old Oct 10, 2010 | 12:30 AM
1973dieselhighboy
were did you get the cooler from
Old Oct 10, 2010 | 09:50 AM
dchamberlain's Avatar
dchamberlain
As I understand it, the coolant flows through the oil cooler, then through the EGR cooler, which you deleted. I don't know how EGR cooler deletes work, but they must have something built into them to allow the coolant to flow through, otherwise the oil cooler wouldn't get coolant either. Is it possible that there is something about your EGR delete that is preventing proper coolant flow?
Old Oct 10, 2010 | 11:10 AM
cheezit's Avatar
cheezit
check cooling fan operation, check the pullies for wear, check the belt and tensioner,
Old Oct 10, 2010 | 01:43 PM
jims406rs's Avatar
jims406rs
the oil cooler came from ford. the egr delete kit is a sinister kit. The cooling fan did not come on. I heard it come on before doing the HG and studs but I did not have the insight at that time so I had no way to monitor the temps other than the oem gauges. I dont think the temps I saw were overly high but from what I have read on these forums I know they are not supposed to be very far apart. belt and pulleys seem to be fine. Where do I go from here?
Old Oct 10, 2010 | 09:09 PM
jims406rs's Avatar
jims406rs
anyone????
Old Oct 10, 2010 | 09:14 PM
moebdick's Avatar
moebdick
Can you get the EOT double checked with another device? Maybe something is wrong with the Edge unit.
Old Oct 10, 2010 | 10:56 PM
jims406rs's Avatar
jims406rs
dont have another device to check with. I cant imagine the edge would be the problem unless all the reading were off. plus when its cold the eot and ect are the same. How can I check my fan and pullies? why would they be suspect? what else could cause this? is it possible the oil cooler kit i got from ford is bad? I would think if it were a coolant flow problem or even a fan issue my coolant temps would be high. they are normal. im really stuck here. can I do any damage driving it with this difference in temp?
Old Oct 11, 2010 | 02:37 PM
jims406rs's Avatar
jims406rs
anyone else have any input or suggestions?
Old Oct 11, 2010 | 05:11 PM
pnj442's Avatar
pnj442
When you did the EGR delete did you keep the EGR valve itself hooked up ?. Cheezit did some research with respect to this and I think he found that depending on the MY, the presence of the EGR valve would affect fan performance.
