instrument cluster change
Old May 19, 2013 | 08:52 AM
wally4684's Avatar
wally4684
Have a 95 F350 with gas engine
No tach. Can I put one with a tach
and no other mods. I changed one
on an 82 and had no problems.
Thanks, Dan
Old May 19, 2013 | 10:05 AM
subford's Avatar
subford
Yes you can just get one from a 1994 or 1995 F-series truck.
Old May 19, 2013 | 12:10 PM
kowboy1's Avatar
kowboy1
Thanks, Dan
I just went thru a similar issue a couple of weeks ago.
I had purchased a tach cluster out of a 97 F350 460 and needed to know what changes I would need to make to make it work in my 95 F150 I6.
There seems to be different opinions about whether it would work and any changes that it might need.
After a few days of research and conflicting answers I decided to install it without making any other changes.
It has worked perfectly in my truck for a couple of weeks now.
The 96/97 F250Hd and F350's were exempt from OBDII requirements (except California trucks) so they, at least in my experience will "bolt right up".
This is the thread..........https://www.ford-trucks.com/forums/1...-question.html
Old May 19, 2013 | 12:20 PM
subford's Avatar
subford
The problem with the 1996 or 1997 clusters in a 1995 is in the RABS part of the cluster.
The problem with the 1992 or 1993 clusters in a 1995 is that it will not charge without repining the plugs.
Old May 19, 2013 | 08:11 PM
kowboy1's Avatar
kowboy1
Are you saying that the 96 and 97 F250HD and F350 OBDI clusters also would have the same issues in the 95 with the RABS? Or is it just the 96 F150 cluster with OBDII?
Old May 19, 2013 | 08:35 PM
subford's Avatar
subford
First off the emissions system (OBD-I or OBD-II) have nothing to do with the cluster nor does the size of the truck (F-150 to F-350). They use the same cluster.
There was a guy on here that was tring to put a 1995 cluster in a 1996 and we never did get the RABS part of the cluster working right. I think he did try doing a mod to get it to work but I think it failed.
Old May 19, 2013 | 10:15 PM
kowboy1's Avatar
kowboy1
Thanks for clearing up about the OBDI and II issue for me subford. Although I'm still confused as to why the switch seems to have worked in my truck.
wally4684, I apologize for hijacking your thread, and I hope I didn't further confuse the issue.
Old May 20, 2013 | 06:25 AM
dixie460's Avatar
dixie460
What part of the RABS system is integrated into the cluster? I have a 96 truck with antiskid and as far as I can tell, the only way the cluster interfaces with it is that it contains a warning light.
Old May 20, 2013 | 07:59 AM
subford's Avatar
subford
Read this thread:
https://www.ford-trucks.com/forums/9...ster-swap.html
And this thread:
https://www.ford-trucks.com/forums/1...star-swap.html
oldproudvet
Nov 8, 2017 07:24 AM
kowboy1
26
May 4, 2013 08:43 AM
sncstealth
Mar 31, 2010 11:10 PM
tpdaniels
Apr 9, 2004 08:31 PM
xericx
1978 - 1996 Big Bronco
Nov 14, 2002 11:55 PM
