tach conversion
Old Mar 29, 2010 | 12:44 AM
sncstealth's Avatar
sncstealth
tach conversion
i was just wondering how many people have replaced there old cluster with one that had a tach
Old Mar 29, 2010 | 03:08 AM
Towmanjbo's Avatar
Towmanjbo
Lot's of us have done this, myself included. After I did it I've heard people talk about needing the correct year cluster for your truck due to a circuit change on the board behind the gauges. I got lucky on my first try so it seems.
Old Mar 29, 2010 | 06:25 AM
BigBlueOx's Avatar
BigBlueOx
Yeah it's best to try to get a cluster of the same year. It's been said that 92-93 interchange 94-95 interchange and 96-97 interchange. 97 being F-250 or F350.
Old Mar 29, 2010 | 07:47 AM
redlightning93's Avatar
redlightning93
Exactly
Old Mar 29, 2010 | 10:00 AM
fordman1090's Avatar
fordman1090
I did mine. I also got a 95 tach that worked fine in my 93. The only difference is that there is an air bag light and a anti-theft light at the bottom left hand side of the cluster next to the left turn light. The amp light is moved to up by the check engine light, and the fuel reset light is gone as compared to my 93. I didn't really check to see if the lights worked on the 95 because i didn't want to buy light bulbs if they were burnt out, but all the gauges worked perfectly.
Old Mar 31, 2010 | 08:01 AM
sncstealth's Avatar
sncstealth
well the reason i ask is i see the horror story about the guy blowing his alternator ever 30 minutes and after i replaced mine the battery died i mean it was old but its still unnerving i guess its just me being worrysome
Old Mar 31, 2010 | 11:51 AM
sncstealth's Avatar
sncstealth
i guess what im saying is should i worry
Old Mar 31, 2010 | 12:24 PM
Virto's Avatar
Virto
Not so long as you have the proper year's cluster. The swap is total cake.
Old Mar 31, 2010 | 11:10 PM
jarod17's Avatar
jarod17
Here is my experience with this cluster swap.
My truck, 1996 F-250 4X4 460
First cluster: Stock with no tach.
Second cluster: out of a 1997 F-250 with tach
Third cluster: out of a 1994 Lightning with 120 MPH speedo
Fourth cluster: out of a 1996 Mustang GT
The '97 cluster swapped in with no problem. The only prob. I had with the lightning cluster was the "abs" light stayed on at all times and the speedo needed recalibrating. Never got around to recalibrating it. I just did the math and knew that if it read 66 mph I was going 60 and pulled the bulb for the abs light.
I have to give props to Frederic for his write-ups on his cluster swaps. They realy helped with the mustang cluster swap.
