Door Panel Removal
BTW our moderator Tom started a tech folder when first coming to this forum--it has a few other similar posts by other members.
I have another under construction dealing with the heater core in '97 and later E-Series vans----not the easiest task but manageable to the truly motivated. If others experiences regarding shop costs for this hired out you'd save yourself the $600-800 labor charges----that's motivating right?
I really huffed and puffed trying to get this panel off until I finally decided there had to be some hidden screws someplace. I was right!
If there is a difference it would be good to note along with photos---this thread part of the Tech Folder I believe.
Thanks!
2001 Ford E150 passenger side panel
Drivers side storage panel (separated from door panel)
Drivers side panel (sans storage panel) showing where two hidden screws reside (aluminum tape at locations)
Ok, here's some photos. There's a photo of the passenger side panel (which was not removed) as is. Of course the other side, my drivers side which has a bad window regulator, is removed. The drivers side panel shows a couple pieces of aluminum tape (I put there so I wouldn't have to edit the photo) where the screws were. One on the left, top hole, and also on the right side.
Once again, I had to separate/remove the storage panel (pry apart) to get at the screws.
When those added-on panels are removed what remains is a stock panel with the hard molded pockets removed.
So yes in your case those extra or hidden screws would be an issue.
I'd thought maybe your panels weren't Ford factory stock, wanted to see your actual parts. None the less you've added a bit to this thread----thanks!
Fishing the lock rod through the panel can be a bit tricky too but not difficult. I will lower the glass to help things along when re-installing as it seems to help a bit---that's not 100% necessary though.
We're here to help if we can!
Thanks!
Any questions feel free to ask.
Also, it turns out that somewhere along the line, someone had broken in through the window as there was a ton of glass shards in the bottom of the door. I manage to pull most of them out with a shop-vac.
Crank door handle for 1999 Ford E series
Its been ages since I've worked on a manual opening door glass---my bad for assuming everyone has power windows. IF you have a few images of removing the interior handle it'd be great sharing them in this thread. I could also add them to those above as I believe this info in in our Tech Folder too.
When I'm replacing a broken door glass once the vacuuming is done I'll open and kinda slam the door closed a few times, even banging gently on the outside to dislodge any pieces caught in the upper parts of the door shell other parts. Nothing more annoying then hearing those little bits bouncing around.
When I want to save a thread for future reference I subscribe to it so its easily retrieved later. Through the User Control Panel its your choice to receive email notifications if/when new replies are added.
A few of my subscribed threads go back to the first year I joined FTE.
I was just going to post a question about removing the door panel. I'm glad I came here first.
Of course, Haynes tells me to remove the screws before they are accessible.
Now maybe I can figure out why the window only goes halfway up.
If the window will only move so far then its possible there is something wrong with the regulator system. Are you removing the door panel to diagnose a problem?
