Clicking coming from front end
Old May 18, 2013 | 09:36 AM
sinnedam's Avatar
sinnedam
2005 FX4 truck. Doesnt click when going straight, but if turning wheel like turning into or out of a parking spot, it makes a clicking noise that gets faster as you get faster. It sounds almost like a baseball card in a bicycle spoke honestly. Dont know if its related, but about 3 months before i noticed the sound I had the Rancho quick lift struts installed on the truck. Somebody told me it could be wheel bearings but in my experience a wheel bearing will make a roaring noise, and it would roar while going straight down the road. This is only when turning the wheels. Also, it doesnt matter if you turn left or right, you can hear it both directions.
Old May 20, 2013 | 11:22 AM
sinnedam's Avatar
sinnedam
Nobody? Please help..
Old May 20, 2013 | 03:53 PM
tw1tch89's Avatar
tw1tch89
It could be the front wheel IWE hubs for your 4wd system. They could be a little catywompus in your hubs and getting out of alignment on turns. I just changed out both of mine. Mine sounded kind of like a ratchet being spun
Old May 20, 2013 | 05:58 PM
sinnedam's Avatar
sinnedam
Thats exactly what it sounds like. Good description. So what did you replace exactly? The hub itself?
Old May 21, 2013 | 07:54 AM
tw1tch89's Avatar
tw1tch89
I replaced both hubs in the front end. I found em on rock auto for about $65 a piece vs $120 at part stores.
Can It be put in 4wd without it skipping out under acceleration? When you put it in 4wd and turn, what happens?
Old May 22, 2013 | 02:27 PM
sinnedam's Avatar
sinnedam
The 4WD seems to work correctly. Do you have a part number on the hubs by chance?
Old May 22, 2013 | 03:01 PM
tw1tch89's Avatar
tw1tch89
Here's the page where I found em.
Part number 600105
You may not need them. Mine was a little more severe and under different circumstances. My hubs were constantly lightly grinding under acceleration. I changed them out last week because they were ground so low that they couldn't engage. I then disconnected vacuum from them because they still had a light grinding noise to them that I didn't like. This indicated a lack of vacuum present to separate the hubs. I'm still looking into that issue.
durtyxthurty
6.7L Power Stroke Diesel
Apr 26, 2018 08:49 AM
blais42
Dec 8, 2014 11:53 PM
Ekkehard
2004 - 2008 F150
Nov 4, 2012 02:58 PM
CobraGT40
Sep 21, 2012 12:26 PM
4x4countryboy
Oct 29, 2011 09:27 PM
