Coolant system flushed
Old May 21, 2013 | 05:37 AM
thinksnow's Avatar
thinksnow
I posted this over on the Expy forums but I know there is a lot more users over here. I flushed out our 07 Expy tonight, it left me a little confused. I drained and collected the old coolant. Topped off the system with water and ran the truck for a while with the heat on hi, then drained the system again. I repeated the process a third time. When I added the new coolant I could only get it to take 7 qts. It should take far more then that. That is going to leave my coolant strength far to low. Should I go for a long drive, come back and drain off more mixed coolant and replace it with pure coolant to increase the ratio. ???
Thanks for the help fellas
Old May 21, 2013 | 03:24 PM
ojai150's Avatar
ojai150
How did you drain it? did you pull the lower hose off the radiator?
Old May 21, 2013 | 08:10 PM
thinksnow's Avatar
thinksnow
No, just used the drain, and what a bitch it is to reach.
Old May 23, 2013 | 10:03 AM
jr105's Avatar
jr105
If you just used the drain on the radiator, the coolant in the block and heater wasn't drained. You can pick up an antifreeze tester for about $5 at any auto parts store to check your mixture.
choate
Sep 30, 2014 11:15 PM
thinksnow
May 21, 2013 03:28 PM
Javo
Mar 26, 2011 11:42 PM
mh5500
Jun 5, 2010 09:14 AM
Lushman
33
Aug 16, 2006 07:52 AM
