Grinding from Front Wheels
Old Apr 23, 2018 | 04:00 PM
durtyxthurty's Avatar
durtyxthurty
I recently was in some muddy conditions and had to use 4 wheel drive to get out. No problems, the 4 wheel drive engaged and I was able to get out, and disengage. Later down the road while going fairly slow (< 20mph) I hit a bump, and there was a loud griding/scraping noise. I stopped the truck, got out and looked to see if something was caught in the wheel/brakes and found nothing, got back in the truck drove and it was fine. This morning, I had it happen again, similar conditions, I believe I was turning left, and the grinding noise started back up, it only lasted for about 20 ft. just like the last time. So I started to do some investigating, I could get it to sometimes replicate the sound when I would turn the wheel all the way to the left, and jerk the truck to the right and left under power in 2 wheel drive. I then got it to do it consistently and turned on 4 wheel drive with the hubs still in the auto poisition, and was able to replecate it in 4 wd again with the wheel all the way to the left. I'm not sure what I did but I was unable to take the truck out of 4 WD (wouldn't disengage), it said it did but the wheels were definitely hopping when turning because they were still in 4WD, and the scraping sound was consistent and wouldnt go away. I tried disengaging multiple times to no avail. Finally, I was rolling forward, and switched it from 4WD to 2WD and it disengaged, also when it disengaged, the sound stopped. When I turned to the left and hit the gas again in 2WD, the sound would come back for a short distance.
Has anyone had any problems like this? And what were your solutions? I'm assuming the transfer case and all components inside are okay because this happens in 2WD. Because of this I can only assume its a bearing in the hub? Is there a way I can test things before buying parts to be sure, I don't want to replace over $1000 worth of parts if this ends up being only a couple hundred dollar fix.
FYI: truck is not lifted, has brand new ball joints, shocks, and sway bar links. Brake pads aren't worn. Just wanted to rule some things out first :)
Thanks!
Dalton
Old Apr 24, 2018 | 04:22 AM
mck2000's Avatar
mck2000
Check for mud between the backing plate and the rotor. Usually air or water will clean it out.
Old Apr 24, 2018 | 05:15 AM
senix's Avatar
senix
It might just be some mud but I'd check those hubs. After a drive are they really hot. Is one hotter than the other?
Old Apr 24, 2018 | 08:48 AM
CascadeF250's Avatar
CascadeF250
I agree with Senex above. Check the front hubs. Jack both sides of the truck up in front and use a stethoscope to listen to each hub as you roll the wheel. You can usually tell when one bearing is bad. That’s how I usually diagnose my front bearing problems. Good luck.
Old Apr 24, 2018 | 10:40 AM
durtyxthurty
So I did this, there is a very slight whine sound when I spin the hub, with the wheel and brakes taken off. Is it supposed to be silent when the hubs aren't engaged and the wheel spins? I know it is supposed to be silent on 2 wheel drives but I also know that parts in the hub are probably still spinning even when the hubs are disengaged, so I couldn't tell if the whine was supposed to be there or a bearing was going out. Also I cleaned the rotor and heat shield, and drove the truck with hubs engaged for 25 miles or so, and now I can't reproduce the sound so I'm hoping either the hubs corrected themselves or there was something caught in the rotor/heat shield/ brake area.
Old Apr 24, 2018 | 01:14 PM
Superdave71's Avatar
Superdave71
Are we sure this isn’t the stability control?
Old Apr 24, 2018 | 03:42 PM
durtyxthurty
No I am not sure, is there a way to test this?
Old Apr 24, 2018 | 05:58 PM
Superdave71
Turn it off and try to duplicate. There are a couple country road corners near me that normally cause the clicking/grinding noise. Sometimes the ‘slippery road’ indicator lights on the dash, sometimes I don’t notice. If I turn the stability control off, the truck is silent in the same corners.
Old Apr 24, 2018 | 08:31 PM
senix's Avatar
senix
So you drove it 25 miles, did you get out and feel the hubs and detect any noticeable difference between the two or any crackling sound like your exhaust pipes expanding or contracting due to heat?
Old Apr 25, 2018 | 12:40 PM
durtyxthurty
I didn't hear any expansion or contraction, however they were warm, but not so warm I couldn't touch them, I assumed it was heat transferred from the brake caliper. I just don't have a baseline for what it should sound like when you spin the hub with the brakes and wheels off, they both make a slight whine because there is some small amount of friction in the hub, I just don't know if that's normal, because of the moving parts that move when the wheel turns or if they are supposed to be smooth as glass and silent like a 2WD vehicle when you spin the front wheel. What I'm saying is the problem could be in both hubs, and they could both possibly have bad bearings, I am just not sure what sound to look for because they both make the same sound, they are either both going out, or they are both fine, I just don't know how to tell which one. Does this make sense?
Old Apr 25, 2018 | 02:39 PM
CascadeF250
The chances of both front wheel bearings going at once are very low.On my last truck The left wheel bearing went bad at 88,000 miles and the right side bearing went at 156,000 miles. Both times there was a noticeable difference between the sound when each side bearing and wheel assembly was spun and listening with a stethoscope. The bad bearing generally very low almost rumbling sound.
Old Apr 25, 2018 | 06:35 PM
senix's Avatar
senix
does not seem to be your issue.
Old Apr 26, 2018 | 08:49 AM
bayou barataria's Avatar
bayou barataria
Grinding could be a u joint.
billionj
Jun 4, 2018 12:23 PM
bigunit54
2004 - 2008 F150
May 26, 2018 01:13 PM
sinnedam
2004 - 2008 F150
May 22, 2013 03:01 PM
Abzack
Dec 1, 2009 01:36 PM
Brian 2002
Jul 21, 2007 06:36 PM
