Perdels
Old May 18, 2013 | 09:23 PM
JT250's Avatar
JT250
I would take a look at 2 and 8. What does it say in a CCT. Buzz test sound good? Have you watched oil shoot out the injectors?
Old May 18, 2013 | 09:31 PM
Tugly's Avatar
Tugly
I dare say those are either tired sticks or maybe new O-rings and copper washers can help. How many miles on the injectors?
Old May 18, 2013 | 10:11 PM
milehi_350's Avatar
milehi_350
3 and 8 fail a cct. I thought that might be the cps though. Did buzz test in November and they all sounded good. Changed injector o-rings in January and did not pay attention to oil spouts when I was in there. Might be worth a couple hours time to investigate, you think?
Old May 18, 2013 | 10:33 PM
JT250's Avatar
JT250
I had two stiks that failed a CCT and had high perdels. I replaced them and now everything runs better.
Old May 28, 2013 | 12:21 PM
milehi_350's Avatar
milehi_350
So when the valve covers were off for the compression test I watched the oil spouts and they all looked the same. The one thing I did find was that the exhaust manifold on cylinder 2 was about 30* cooler than all the others. It also took a lot longer to get up to a steady temp than the others. I let it idle about 25 min.
Old May 28, 2013 | 01:10 PM
Tugly's Avatar
Tugly
Ah... very good detective work my friend. #2 just jumped to the prime suspect. Between the Perdels and the cooler temperature, I think you've got your idle disruptor.
dmueller71
Jul 23, 2019 08:11 AM
Shawn MacAnanny
Oct 31, 2016 01:16 PM
mjtpolice76
May 23, 2014 08:27 AM
MYFORD250
Oct 8, 2012 09:24 AM
sdunn9
Feb 18, 2011 05:17 PM
