Perdels
Old May 17, 2013 | 03:27 PM
milehi_350's Avatar
milehi_350
Perdels
Could perdel readings point to tired injectors, or my vibration at idle?
Old May 17, 2013 | 04:09 PM
mueckster's Avatar
mueckster
Yes. They can.
Old May 17, 2013 | 04:56 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Perdel. Percentage of Deceleration.
A faulty fan clutch or worn out serpentine belt can sometimes throw perdel readings off as well. Some CPS types will also skew the perdel readings...
Perdel is just a reading of relationships....so it simply measures how evenly each cylinder is contributing to the rotational operation of the engine. If all the injectors are evenly worn out....then the perdel readings won't show any differences. Once an injector is performing much better or worse compared to its neighbor (in the firing order), then the perdel test might be able to detect that.
Old May 17, 2013 | 05:16 PM
JT250's Avatar
JT250
It can point to it, but not decisively diagnose.
Old May 17, 2013 | 05:26 PM
mueckster's Avatar
mueckster
This is true. I replaced my stock crankshaft damper with a Fluidampr and it lowered my perdel percentages. Reading perdels can point to a cylinder/s that are contributing less than others, but other testing must be done to pinpoint the source of the problem.
Old May 17, 2013 | 06:21 PM
milehi_350's Avatar
milehi_350
So what would be 'okay' readings (other than 3 and 8 being different right)?
Or what readings would point to an issue?
Old May 17, 2013 | 06:39 PM
jeffreyt's Avatar
jeffreyt
I'm chasing a vibration at idle too. Enough for change to rattle a tad, but not horrible. I'm not concerned about it, just aware. My thoughts are this order : 1) crank shaft pulley 2) torque converter 3) engine mounts 4) injection.
I'm not sure reading perdels would single out any of the issues, just point to AN issue.
Old May 17, 2013 | 06:44 PM
Tugly's Avatar
Tugly
Perdels can be weird. I thought it was PERcent DELineation, but I never found this in writing.
I have seen a Perdel of 6 on a smooth-idling truck and a rough-idling truck, so you have to take all the symptoms together. The rough-idling had a black CPS and was smoking, but it was a loose injector. The smooth-idling truck had a gray CPS. I've had a reasonable idle with a true reading of 2 or 3.
Here's more fog for the bank: You can have a "bad" injector that shows a difference in the idle when you unplug it - while it's weak, it's not necessarily dead. Observation, CCT, and a cold buzz test combined can help point to a bad injector... but putting new O-rings and copper washers on the sticks, plus rotating their position and conducting the same tests is the only way I know to verify. This is assuming it passed the buzz test. A weak-sounding buzz test means first check UVCH and test again (assuming good oil). You can see how this is as much art as science. It's all about not throwing a grand in there to "test" a theory that the sticks are bad.
If you still have that rolling idle, that's tuning... I learned that one.
Old May 17, 2013 | 06:47 PM
jeffreyt's Avatar
jeffreyt
Easy test for tuning, just pull the chip or revert to stock...
Old May 17, 2013 | 07:29 PM
Shake-N-Bake
Originally Posted by Tugly
[FONT=Georgia]Perdels can be weird. I thought it was PERcent DELineation, but I never found this in writing....
Same here. I saw a tech sheet one time for a Rotunda machine that talked about Percentage of Deceleration in regards to gasoline engines so that term sorta stuck with me. A Ford tech that I spoke to thought it might mean Percentage of Delivery....which makes sense but we couldn't find it in writing anywhere. The 'deceleration' term registers best in my head to describe the measurement so that is what I use when discussing with folks.
Old May 17, 2013 | 08:20 PM
milehi_350's Avatar
milehi_350
So their is no normal range for these numbers?
Old May 17, 2013 | 09:26 PM
Shake-N-Bake
5% or less is acceptable according to Ford. 5-10% is cause for investigation and over 10% usually results in getting an injector replaced. Again, according to the dealer.
Old May 18, 2013 | 07:30 AM
Tugly's Avatar
Tugly
In my personal experience, I have used the CCT when I knew I had a bad hole and I wanted to isolate which one was the likeliest suspect... and it works for this. When my injector prairie-dogged, it disrupted the fuel to the cylinders that fire before and after it, so in my case... a series of three bad Perdels in firing sequence pointed at the one in the middle. The firing order includes 6, 8, 1, and all three were bad in the CCT - the culprit was #8.
The graph below was a poor-flowing #1 at idle:
Old May 18, 2013 | 10:41 AM
JT250's Avatar
JT250
Cause for concern TO ME is above 3. That is when I would start investigating. I had as bad as 9. I have 2 injectors right now that go from .5 to 2. The rest are below 1.
Old May 18, 2013 | 05:14 PM
milehi_350's Avatar
milehi_350
Okay, my max numbers are...
1 1.3
2 6.0
3 2.9
4 1.9
5 2.1
6 0
7 .9
8 6.6
