05 turbo
Old May 17, 2013 | 11:23 AM
mrwrench's Avatar
mrwrench
05 turbo
I dont hear the turbo sound in my 05 f250 - very low psi - I disconected de cac hose and it doesnt blow . turbo is clean -runs ok no codes
any opinion >?
Old May 17, 2013 | 11:53 AM
mrwrench's Avatar
mrwrench
any????????????
Old May 17, 2013 | 12:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Turbo carboned up on the hot side causing vanes to stick, maybe the VGT actuator. Need a gauge to see what's happening. You can pull the Intake tube between the air cleaner and turbo and check turbine wheel for damage or rubbing inside the housing and shaft for end play and radial play. It makes very little to no pressure at idle. Not really a valid check. The engine needs some rpm and a load on it to run the boost up.
Old May 17, 2013 | 02:16 PM
mrwrench's Avatar
mrwrench
I cleaned the turbo last monday , it wasn't stick .
Im suspecting on the actuactor , when the turbo was open I could't move the dowel with my fingers , only with a plier . maybe the actuator linkage is making resistance .
arkredneck
Jun 30, 2014 05:59 PM
OriginalOutlaw
Sep 17, 2013 04:54 AM
4bigred
Nov 8, 2008 01:38 PM
My05-F350-FX4
Sep 25, 2007 11:56 PM
JTP0110
Dec 29, 2006 01:00 AM
