High coolant temp...?
Old Jun 9, 2013 | 07:21 PM
  #46
shaferz's Avatar
shaferz
Latest update..
Went to a friends house today who had an IR temp gun... Not sure how accurate the actual readings are but i was more looking to see how much of a temp drop I am getting at the outlet of the radiator. Temp of outside of hose just after the tstat neck - max of 170-175f. Temp on bottom radiator hose was max 140-150. Truck had been idling for about 5 minutes. ECT and EOT according to Torque app were 207 and 209 respectively. If just left to idle, the temps drop down to these readings. If driving, temps go back up to 220+. While cruising, I am not seeing a change in temps really if I get the RPM's up (trying to rule out water pump.)
New issue as well... Or at least something I just now recognized. Went WOT today for the first time and noticed a 'miss' or something at WOT. This symptom did not exist before I took the truck in for all the work.
Positive that the two issues (high temps and misses) are not related, so who knows. Updated RCD via email... Asked them to call me early tomorrow morning.
Will update you guys when i get some news.
Old Jun 9, 2013 | 07:34 PM
  #47
diesel_dan's Avatar
diesel_dan
Originally Posted by Rusty Axlerod
I have a few gadgets but haven't bought a temp gun yet. Not sure what those temps should look like.
You should get one! I bought a cheap Harbor Freight unit to test some chimney pipe on a stove (heating) I put in. Worked great up until I shot the wife in the A$$ with it...
Still can't see out of the right eye yet....
No idea where the gun is either........
Old Jun 9, 2013 | 07:37 PM
  #48
Per4mance's Avatar
Per4mance
^^he's to funny....ba ha ha ha !!!!
Old Jun 9, 2013 | 08:04 PM
  #49
BigRodsAuto's Avatar
BigRodsAuto
Heating Up
You may want to look at, water pump also radiator hoses that can collapse under pressure. I know it sounds weird I had a 76 f250 hiboy with a 351w that would over heat then it wouldn't?
Water pump had good flow but as I was adjusting carb I happened to look down as I accelerated engine and watched lower hose close shut replaced it with a new one, guess what so did the new one. I made my own coil spring with a wire coat hanger put it inside hose and problem was gone!
Old Jun 9, 2013 | 08:15 PM
  #50
shaferz's Avatar
shaferz
Thanks. I guess collapsing hose is always possible...? Both upper and lower hose are firm at idle with engine hot.
Old Jun 9, 2013 | 08:43 PM
  #51
diesel_dan's Avatar
diesel_dan
In a word: No.
Old Jun 9, 2013 | 09:27 PM
  #52
BLADE35's Avatar
BLADE35
Thanks for the reply.
Fan is operating correctly and coming on STRONG at 219+.
Not sure when degas cap was last replaced... Not in the past 9 months anyway. The system does hold pressure, as there was still pressure when I removed the cap this morning while checking things.
I've read about the 03 water pumps. Fack.
Guess I will wait to talk to RCD monday morning.
According to Ford Values that's Low
Below is KOEO--Low Idle--High Idle Values
With truck @ ECT/EOT 190*+and in Park with A/C Off
<table width="543" dir="LTR" border="1" cellspacing="0" cellpadding="7"><tbody><tr><td width="20%" height="3" valign="TOP"> FANSS
</td><td width="20%" height="3" valign="TOP">Fan Speed
</td><td width="20%" height="3" valign="TOP">0
</td><td width="20%" height="3" valign="TOP">533
</td><td width="20%" height="3" valign="TOP">488
</td></tr></tbody></table>
Old Jun 9, 2013 | 09:40 PM
  #53
shaferz's Avatar
shaferz
Sorry... I was talking about ECT of 219. Will get fan speed readings tomorrow morning first thing. 219*F is when the thing sounds like it will lift off. lol
Old Jun 9, 2013 | 09:46 PM
  #54
BLADE35's Avatar
BLADE35
Oh OK!!!
Sounds good then at High ECT Temp anyway
Does Fan come on in Lower Temps Like the Post above
Old Jun 9, 2013 | 09:50 PM
  #55
BLADE35's Avatar
BLADE35
If you Know your HeadGaskets are toast then theres likely the Overheat or Temp Spike Issue
Old Jun 9, 2013 | 09:52 PM
  #56
Fal-308-Win's Avatar
Fal-308-Win
Is the fan shroud still on the truck and in one piece?
Old Jun 9, 2013 | 10:06 PM
  #57
shaferz's Avatar
shaferz
Yes... Fan speeds are definately registering at idle. Do not know exact numbers, but I'm pretty sure they were within the range you posted.
Head gaskets better not be toast. I just got the truck back 4 days ago with 2 new heads, head gaskets, ARP studs, EGR delete, coolant filter, fuel filters, blue spring, banjo bolts, etc.
Yes... Fan shroud is all there and in place.
Old Jun 9, 2013 | 11:12 PM
  #58
bismic's Avatar
bismic
What head gaskets did you use?
Old Jun 9, 2013 | 11:17 PM
  #59
shaferz's Avatar
shaferz
Pretty sure they were Ford gaskets. I think they come with the heads? Will find out tomorrow when I talk to RCD.
Old Jun 9, 2013 | 11:35 PM
  #60
BLADE35's Avatar
BLADE35
Hope you did a Oil Cooler TOO!!!!!!!
How about front cover and water pump
Check ECT and EOT Sensor Plugs to make shure they are plugged In fulley
In Fact check all the Wire harness since you had Open Heart surgery recently
