High coolant temp...?
Old Jun 11, 2013 | 09:52 AM
  #76
shaferz's Avatar
shaferz
Not sure why I was freaking about the possibility of needing to replace the radiator. Just priced one out, and local dealer sells them for $269.xx.
Still hoping the issue is just the water pump.
This fricking truck is changing me. I used to think a few hundred dollars was a lot to fix a vehicle. After dropping the coin I have on this truck recently, I am all of a sudden 'content' with $1k! WTF?
Old Jun 11, 2013 | 10:48 AM
  #77
HokieHiVPI's Avatar
HokieHiVPI
Damn, that's not bad at all. I thought they were around $500. I hear you on the pricing. I've dropped around $3k in my "new" truck over the last month getting her right, but honestly, I haven't shed one tear... yet. I bought it at a great deal knowing there'd be money to be invested.
Any MORE money may result in open weeping.
Old Jun 11, 2013 | 11:08 AM
  #78
shaferz's Avatar
shaferz
Update: water pump is fine. No crack, and really no wear. Bearing is smooth and pulley had no wobble.
They said the radiator smells like 'stop leak'
Waiting to make sure they can get a radiator here today. (He thought it would be by 2pm!) If so, they'll drop a new one in.
In researching right now, I have read more than one story about people using 'stop leak' and having their vehicles run 20* hotter afterwards. Interesting tid-bit - that is about how much hotter my Excursion is running than it should be!
Will update as I know more.
Old Jun 11, 2013 | 11:44 AM
  #79
Per4mance's Avatar
Per4mance
Flush the snot out that bad boy !
Old Jun 11, 2013 | 11:47 AM
  #80
69cj's Avatar
69cj
I've never had much luck getting stop leak out of a cooling system. The black stuff anyway. The only type I will use any more and only in an emergency is Alumaseal stop leak.
Old Jun 11, 2013 | 11:50 AM
  #81
HokieHiVPI's Avatar
HokieHiVPI
Ugh, that stuff should be outlawed... or at least have a shelf life where it disintegrates after 1000 miles.
Old Jun 11, 2013 | 12:44 PM
  #82
04badford's Avatar
04badford
X2 on that, may need to do the v-c9 chem flush, the guys here would know if it would break the stop leak down enough tho,I have had good luck with 1800 radiator life time ,I have the radiator in two of my trucks and they have been reliable with no temp or leak issues .
Old Jun 11, 2013 | 05:14 PM
  #83
69cj's Avatar
69cj
VC-9 is a rust and scale remover, similar to a boiler cleaner. I think it would be a waste of time and 50+ bucks. The black, Prestone and similar, stop leak is designed to plugs things up and does a bang up job of it.
Old Jun 11, 2013 | 06:19 PM
  #84
04badford's Avatar
04badford
OK thats what I thought thanks 69cj, so bad news for the egr and oil coolers with this in the radiator I take it.I remember back in the day some car lots would run saw dust not nearly effective as stop leak but then again careful about parts you cant see
Old Jun 11, 2013 | 06:33 PM
  #85
69cj's Avatar
69cj
And in the 60's we would put banana peels in the rear end to quiet the diffs. down.
Old Jun 11, 2013 | 07:42 PM
  #86
BLADE35's Avatar
BLADE35
That Stopleak Collects around the Heads and Gives Nice Hot Spots on the Cylinders
The Only way I have got it Out is too Pull the Heads And Vacum it Out
Old Jun 11, 2013 | 08:22 PM
  #87
shaferz's Avatar
shaferz
Sorry about the late update. New radiator went in and solved the problem.
Drove the hour and 15 minutes home in 87* weather and coolant temp never went over 200*! Generally stayed 187-194 depending on traffic.
Tried to turn on the a/c for the first time since last fall to find that I only get cold air at idle? As soon as I'm driving... Temp out of the vents goes back up to ambient.
WTF? If its not one thing, its another. Ugh.
Old Jun 11, 2013 | 08:44 PM
  #88
Per4mance's Avatar
Per4mance
That's a ez fix.Go to wally world and get one of those recharge cans for $30.00 and your good to go
Old Jun 12, 2013 | 06:22 AM
  #89
shaferz's Avatar
shaferz
Think thats all it is? I might actually have one in my garage! Gonna have to go check!
Old Jun 12, 2013 | 07:17 AM
  #90
shaferz's Avatar
shaferz
Just read that some folks with tunes have similar issues. Gonna drop the stock tune back on this morning and see if there is any change.
Of course I couldnt find my 're-charge' can in the garage! Ugh!
