P1316 code after installing glow plugs
Old 05-10-2013, 04:10 PM
PJ-Hunter's Avatar
PJ-Hunter
PJ-Hunter is offline
I wrote in a week ago with a rough start issue. Turns out it was the pass side GPs were bad. So I replaced the GPs and now I get a kinda hard start and it runs rough. Throwing a P1316 code. Didn't throw that code before at all.
Ideas???
Old 05-10-2013, 04:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Check the wiring harnesses to the injectors. You may need to go back under the valve covers to check your work.
Old 05-10-2013, 09:02 PM
PJ-Hunter's Avatar
PJ-Hunter
That was it. Somehow I knocked the front most injector plug off when putting the VC back on.
I can tell you this, whatever stupid engineer thought it was a great idea to cram such a large motor in such a small space seriously needs his head examined after a sound butt whoopin!
Old 05-10-2013, 09:13 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Engineers need to work on what they design . If that does not teach them to do better , they should be drowned in their own urine !
Old 05-12-2013, 11:30 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
Would you rather have a smaller engine in there?
Old 05-12-2013, 01:41 PM
PJ-Hunter's Avatar
PJ-Hunter
No, but all the other stuff like air boxes and hose routing is just plain dumb. Two of those VC bolts I could hardly get a wrench on.
Old 05-12-2013, 03:00 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
It is not just our beloved Fords that have this issue ! Most makes are difficult to work on . You would think a big truck would have more room to work . Try replacing the injectors on an FL80 with a cat . Even worse put a head on the beast ! The japs cornerd the market on hard to work on . Now all are hard to work on !
Old 05-12-2013, 07:45 PM
tdpower's Avatar
tdpower
tdpower is offline
Ideas???
I don't think your glow plugs were bad. Did you ohm them out at the GP? You need to do a buzz test with something like AE to get the idm stored code.
Old 05-13-2013, 06:39 AM
Tugly's Avatar
Tugly
Tugly is offline
You want a 13 mm flex socket. I can pop either VC in 15 minutes with the right tools - here's the kit I use for injectors and cups:
jayc3169
06-23-2022 06:53 AM
pilgrimbizket
02-08-2016 07:45 PM
goosehunta
01-22-2012 08:00 PM
Joe28443
03-26-2010 06:32 PM
BodegaErik
07-02-2006 10:20 PM
Quick Reply: P1316 code after installing glow plugs
