window regulator motors...
Old May 9, 2013 | 09:34 AM
Christof13T's Avatar
Christof13T
Will the window regulator motor from the drivers side door of an 82 f150...
Fit in a 92 f250?
My 82 is down... and will remain down until i find a 4bt on the cheap to stuff in her mouth...
My buddies f250 just lost the ds window motor...
Tested switch... good +- 12v depending on switch direction... motor coil reads wide open.
If mine will fit then problem solved...
Anybody?
Old May 9, 2013 | 01:17 PM
jas88's Avatar
jas88
I am going to guess and say it will. I have a motor in my '91 that is out of an '85 Crown Vic, so there is quite a bit of crossover.
Old May 9, 2013 | 02:04 PM
Christof13T
Cool...
Thats the answer i needed...
80-86 86-96 changes were my worry...
Donkey chains!
Old May 9, 2013 | 02:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Christof13T
Will the window regulator motor from the drivers side door of an 82 f150...Fit in a 92 f250?
1982 is not the same motor as 1992...and window motors are right & left specific.
F43Z-54233V94-BRM (replaced E43Z-5423394-A) .. Right Front Window Motor
F43Z-54233V95-BRM (replaced E43Z-5423395-A) .. Left Front Window Motor
1987/92 F100/350 & Bronco / 1984/92 Tempo/Topaz.
E5TZ-10233V94-ARM (replaced E5TZ-1023394-A) .. Right Front Window Motor
E5TZ-10233V95-ARM (replaced E5TZ-1023395-A) .. Left Front Window Motor
1981 F100/350 & Bronco from 10/80 / 1982/86 F100/350 & Bronco.
Nylon window motor gear notorious for stripping and/or lube dries out-window motor no longer works.
DOAZ-62234A24-B .. Window Motor Nylon Gear Kit-Includes bottle of lubricant / Available from Ford / Autoparts stores for about 20 bucks.
1970/92 all FoMoCo Passenger Cars / 1981/92 F100/350, Bronco & Econoline.
Old May 9, 2013 | 04:03 PM
Christof13T
I knew about the bushing things... i had already replaced them in both motors on my 82.
And still have a spare gar somewhere...
Tested the motor itself.
Motor is bad.
Can i use the motor from my 82 on the 92? Same door... drivers side...
What would the difference be in fittment?
Old May 9, 2013 | 05:08 PM
jerwiltho's Avatar
jerwiltho
Check with auto zone or one of the other parts houses and see if the part numbers are the same.
Jerry
Old May 9, 2013 | 05:45 PM
White 97 xlt's Avatar
White 97 xlt
Jerry
I'm sure autozone knows so much more than FORD, about what FORD put into these trucks........
Please reread post number 4!!!!!!!
Old May 10, 2013 | 03:30 PM
jerwiltho's Avatar
jerwiltho
I'm so sorry. Guess I should be more careful reading the posts. I hope I haven't caused any problems here. I do appreciate all the good knowledge here, as I have used a lot of it myself.
*2fords*
Jul 17, 2009 01:24 PM
1fordtruckman
Oct 22, 2007 07:44 AM
pherve
Jun 7, 2007 04:21 PM
adrock
1978 - 1996 Big Bronco
Mar 16, 2005 08:50 PM
thundercatsteam
Bronco II
Jan 17, 2003 01:52 PM
