Any one know were I could get a cheap window motor at for my bronco II 1988.
And that is not over $50 bucks for the motor.
Please let me know it would help alot.
You can put in a full size Bronco window motor. The only difference is the length of the harness. These are more plentiful at junk yards. I would look at the harness in the door being bad. Driver's side usually dies well before the pass. window.
check to see if you can hear the motor runnin first. if you hear the motor run but the window doesn't move then you have a bad gear if you can't hear it at all then you have either a bad motor or a bad connection.I had the same problem but you could hear the motor run. when I pulled it apart it was only the gear. the gear cost like $5. motor was $60.
