lowering my truck
Old 05-03-2013, 07:01 AM
99F250LDEXTCAB's Avatar
99F250LDEXTCAB
99F250LDEXTCAB is offline
lowering my truck
i have a 99 f250 l/d 2wd and im looking to lower it, see i have a good friend that has a machine shop, and i was wondering if i can just modify the front leaf hanger so it drops the rear 4 inch's, would it still line up properly and would it hurt my rear end or drive shaft
Old 05-03-2013, 10:20 AM
Bilster's Avatar
Bilster
Bilster is offline
The aftermarket sells hangers that will lower it two inches. You can get the extra two by purchasing a used set of springs from an Harley Davidson...or the aftermarket, if you budget allows. I don't think 4 inches is enough to cause drive shaft angle problems. You might have to purchase a shorter pair of shocks.
Old 05-03-2013, 12:56 PM
99F250LDEXTCAB
thanks
thanks but since i have access to a machine shop we can easiesly make our own pieces like factory just longer to get lower thats to much for aftermarket kits that only go 4" with shackle and leafs, my springs are perfect so thats not in the budget but a cam swap is
Old 05-03-2013, 03:28 PM
99F250LDEXTCAB
do you know how many inches
do you know how many inches i can lower the front of my f250 l/d 2wd with factory spindles and a arms, and sway bar linkages ? thanks
Old 05-03-2013, 10:10 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
how do you plan to lower the front ?
Old 05-03-2013, 10:15 PM
99F250LDEXTCAB
coil springs
changing the coil probably would ruin them if i cut them so id have to get new coils
Old 05-04-2013, 08:48 AM
steve(ill)'s Avatar
steve(ill)
Old 05-07-2013, 10:49 PM
kabcpapc's Avatar
kabcpapc
kabcpapc is online now
I have the opposite problem. My 1997 F150 Supercab 2wd shortbed is lowered 2" in the front by using shorter coil springs and 4" in the rear by using shorter spring hangers. See my post. I did have to use shims to align the driveshaft. You probably would have to do the same or you would get vibration problems. According to DJM as mentioned in one of the posts, the shorter front coil springs are the same for my truck and yours.
Would you interested in swapping your stock parts (front coil springs and front leaf spring hangers) for my lowered parts even steven? We could pay the freight charge to ship the parts to the other person. I don't know where you are but I am in Macon, GA.
Old 05-08-2013, 12:53 PM
99F250LDEXTCAB
i would be interested but my truck is our only transportation so i couldnt send the parts untill i get urs and will ur front coils be the same as mine, mine coils are twice as thick as the f150 coils im in cape breton, ns, canada
Old 05-08-2013, 06:55 PM
BCHauler's Avatar
BCHauler
BCHauler is offline
I have a 99 f150 2wd and I purchased heavy duty f250ld coil springs to replace my 310K stock coils. Holding them side by side they are the same size. Different compression rate. They are interchangeable between the f150 and f250.
Old 05-08-2013, 07:02 PM
99F250LDEXTCAB
ya ill do it but like i said this is our only rig so i cant strip it till i have somthing to put in it
Old 05-09-2013, 05:36 AM
99F250LDEXTCAB
ya ill do it but like i said this is our only rig so i cant strip it till i have something to put in it
BRay09
10-03-2015 04:45 PM
Silverfox0921
07-21-2015 06:18 PM
fordpower46
06-07-2012 11:43 PM
pdrhodes1
05-08-2009 01:04 PM
300sixowner
02-03-2004 04:47 AM
Quick Reply: lowering my truck
