recently ive decided to do all the top end gaskets on my bronco, it has the fuel injected 5.0 v8, and the lower intake is rough, i dont have the money to replace it i gotta go with what i have, i was wondering if a skim coat of black rtv on the lower intake's gasket surface would hurt anything, its got some minor pitting on the gasket surface and i dont know if the gasket by itself will seal it properly any advice??
Don't see why it would hurt anything. As with any product, make certain it has properly cured and that none gets into intake runners or coolant cross-over passages. Otherwise, the goal is a good seal between intake components to prevent vacuum leaks. Do what its takes to ensure this simply because vacuum leaks WILL muck with the ECM and vital engine control parameters.
are you saying that the surface is pitted? if so the new gasket should seal.. the pitt's shouldn't hurt anything. make sure you tighten in the correct order and to the correct torque spec.
how bout a pic to see the pitting..............
Reason: edit
see now, my book does not have a tightening order for the 5.0 intake, only the lightning models have a listed pattern for bolt removal and installation, i searched hi and low online for a tightening order for that intake and came up with nothing so i just start in the middle and do a cross pattern ill post pics when im done, the worst is around the egr ports there are two areas where its quite deep im just gonna use a little black max should do the trick
