Wiring help
Old May 7, 2013 | 06:55 PM
KY_FORD's Avatar
KY_FORD
Wiring help
Recently purchased a 1986 f250 460. I've had the unfortunate experience of finding a rats nest of wiring the PO has made under the dash. The real problem here is that the truck can't be driven because the brake lights and turn signals don't work. Given the severity of the mess, I thought I could buy a new wiring harness and re-wire it, but LMC wants $640 for a generic harness.
I can't seem to justify that expense for a farm truck, but I also want the truck in good working order. I'm not an electronics expert but I'd welcome ideas for alternatives.
Seems that there aren't many older f250s at the local pick and pull salvage yards.
Old May 7, 2013 | 07:23 PM
81Bronk36's Avatar
81Bronk36
buy a haynes manual, flip to the back, trace the wires with colored pencils that loosely represent the colors they say they are, then find them under the dash and figure out where your problem is. Might just be the turn signal flasher too, have you replaced it?
Old May 8, 2013 | 01:17 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have a similar situation right now.
My truck keeps popping the fuses (1&5) for the brakes and turn signals.
Though our wiring is different year to year, the problem might be the same one.
I am posting to subscribe this thread, and will let you know what I find.
Old May 8, 2013 | 11:43 AM
KY_FORD's Avatar
KY_FORD
I ordered the Haynes manual over the weekend. Should be here any day. I have power at the fuse block on all fuses. The parking lights and headlights are working. I saw the hazardsashing briefly when I was messing with that switch, but now it's not working. This leads me to believe the relays are fine. So there must be a bad connection in the steering column or under the dash. The PO changed the column because the tilt wheel broke.
Guess I just need a whole lot of time an a tester.
Old May 8, 2013 | 03:47 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
As far as wiring, Haynes manuals are almost useless. Archion has my 1986 EVTM so I can't look at it for you.
Old May 8, 2013 | 04:36 PM
joshofalltrades's Avatar
joshofalltrades
the brake lights, turn signals, and hazard lights all run through the turn signal switch, and i've heard of that switch failing and knocking out all of them. thats where i would start looking.
jim, seeing that you're popping both fuses, i would suspect you have a problem somewhere further back, likely a short to ground in the trailer light wiring. but follow the whole harness and look for and damage.
Old May 8, 2013 | 04:48 PM
Franklin2's Avatar
Franklin2
Since you messed with the hazard switch and something happened, take the hazard switch and work it up and down rapidly 6 or 7 times and see what happens.
And also don't forget, these trucks are famous for the keyswitch not returning to the proper position after the engine is started. After you start the engine, lightly wiggle the key back and forth and see what happens. This will usually affect the wipers and the guages, but can also affect other circuits.
Old May 8, 2013 | 04:49 PM
joshofalltrades
my experience with the ignition switch wiggle is that it only affects circuits that are switched by the key. that means it won't affect brake lights or hazard lights, but will affect turn signals, gages, wipers, etc.
Old May 8, 2013 | 05:09 PM
Franklin2's Avatar
Franklin2
That's true, the turnsignals would be the only ones affected.
Old May 8, 2013 | 09:10 PM
ctubutis's Avatar
ctubutis
The EVTM is FAR superior to a Haynes or Chilton manual
1986 Ford Bronco and F150 F250 F350 Electrical Troubleshooting Manual
Old May 8, 2013 | 09:11 PM
85lebaront2
Yes, that's what he needs. Mine is in WV.
cliffs750
Aug 26, 2015 10:11 AM
Farminwithmyford
Mar 10, 2015 06:51 PM
myklstrng
Oct 22, 2010 11:53 PM
Grut
Sep 21, 2007 06:56 PM
96brco
Jun 26, 2006 09:41 AM
