Trailer Plug Wiring
Old May 7, 2013 | 04:00 PM
jayro88's Avatar
jayro88
Trailer Plug Wiring
Okay, so I am finally digging into installing a 7 pin connector and brake controller on my '88 E250. It had a 4 pin that the previous owner told me he had spliced in. I unwrapped the electrical tape and found this
I then started digging under the dash and found this
Now does this mean that at some point this vehicle already had a 7 pin/brake controller and that this is the wiring for it? If so, I should be able to just add the 7 pin and hook up the controller to the existing wiring....correct?
Thanks
Old May 8, 2013 | 09:49 AM
thomabb's Avatar
thomabb
Every brake controller I have seen has 4 wires coming off it. That plug looks like a 3-wire to me.
Do you have a volt / ohm meter? With a meter and a little detective work you should be able to figure out what those wires are and where they go. They could be abandoned brake controller wires, and easily brought back to life for your install.
Old May 8, 2013 | 11:59 AM
jayro88's Avatar
jayro88
Thanks. I am going to get my meter out to test and make sure. I know most of the plugs now have 4 wires because they have one for a dash light. Since my van in so old (1988) I don't believe it has one. If that plug is not it, I will have to dig under the dash some more. That one just popped out when I looked under.
Old May 8, 2013 | 12:51 PM
thomabb's Avatar
thomabb
Wires out the back of the brake controller;
blue - brake voltage
red - brake light
black - +12v
white - ground
No dash light.
Old May 8, 2013 | 07:48 PM
jayro88's Avatar
jayro88
red - brake light
black - +12v
white - ground
No dash light.
Thanks. I will dig into it further.
Old May 9, 2013 | 09:11 AM
p-paw's Avatar
p-paw
4th Gear
Sorry to advise that Ford did not make any factory installed wiring on the '88 year models and more specifically the "E" series vans had even less wiring than most trucks. The wiring in your photo has wiring with tracer colors (i.e. red and blue wires with black stripe) that were never part of Ford trailer wiring scheme. I think you may be looking at some wiring installed by previous owner. Your model van normally requires all new hard wiring from front to rear by consumer to install/use a brake controller. Good Luck.
Killer RC
60
Nov 14, 2020 04:21 PM
thebandit343
Apr 14, 2012 07:04 AM
tegbaw
Aug 9, 2007 07:27 AM
scottddove
All Things Towing
May 16, 2006 12:55 AM
ChesBayCaptain
Aug 19, 2004 08:36 AM
