General Mods Question
Old May 7, 2013 | 03:56 PM
cowmilker08's Avatar
cowmilker08
The transmission supposedly is upgraded, which doesn't really matter cause the next truck where these will end up is going to be a stick.
Old May 7, 2013 | 03:58 PM
cowmilker08
Originally Posted by Bill97
Mine makes 27-30 pounds of boost with 1's. I think the limit for this turbo is 30 pounds of boost? I've heard of a few people running II's with stock turbo, but I would think it's a ticking time bomb if you're running it hard.
If you do 1.5's just have an emergency fund to replace it - but like my earlier post you will wish you had II's if you have to upgrade a turbo, and a tran's.
LOL, if i had 2's then I'll wish I went with 3's...
Old May 7, 2013 | 04:11 PM
cowmilker08
Originally Posted by cowmilker08
Would the stage 1.5's be too hard on a stock turbo? They have a 30% nozzle.
FWIW, I asked Jim about it. He says that Stage 1's are as high as he would go with a stock turbo. So I'm gonna listen to him on this one.
Old May 8, 2013 | 11:44 PM
bryanlindborg600's Avatar
bryanlindborg600
from what i remember you could buy stage 2s and have your chipped burned as if they are stage 1's then if you ever wanna bump up the power you already have the injectors and just need a chip re-burn after other supporting mods. that is what i will be doing when i get injectors unless i'm completely wrong in that line of thinking..
the cost are the same between the stages so might as well have them in there if you can!
Old May 10, 2013 | 08:26 AM
cowmilker08
Thats a good idea.
Does anyone else know if that can be done?
Old May 10, 2013 | 08:48 AM
DIYMechanic's Avatar
DIYMechanic
I'm fairly sure it is as simple as just keeping the tunes turned down. So if you have a 60, 80 and 140 tune, you just run the 60 or the 80 and not the 140... Talking with the tuner of your choice would be the best route to go. Really the only difference between a stage 1 and a stage 2 generally is the size of the nozzle. The 2's won't atomize quite as well at idle but will run better under power if you have the oil to keep up with them. That's my take on it anyway. Travis would be a good one to talk to about this, since he has personal experience running quite a few different configurations of injectors and tunes.
Old May 10, 2013 | 09:06 AM
Bill97's Avatar
Bill97
As I mentioned earlier - key point is keeping them tuned down until you have the supporting MODs. The temptation is still there to say, "one time won't hurt" I know I would, then I'd be replacing things sooner than expected!
Old May 10, 2013 | 04:34 PM
cowmilker08
I'm gonna stay with 1's since I don't know if I ever will get that into modding.
Old May 10, 2013 | 05:41 PM
fordpride's Avatar
fordpride
I remember saying that lol
I got stageI's then 3 months later got stageII's 180/80's
Dezl Newbie
Jan 29, 2017 05:40 PM
bass-n-fire
19
Feb 27, 2015 11:40 AM
Nabors
Oct 23, 2014 03:43 PM
bigrig410
18
Sep 18, 2009 06:22 AM
Rick2001
Oct 7, 2007 11:51 AM
