fuel filter
Old 05-06-2013, 09:22 AM
RobertJohn's Avatar
RobertJohn
RobertJohn is offline
fuel filter
My 7.3 is the early model and everytime i get a new fuel filter with the cap attached it just won't fit or tighten.
Am I don't something wrong ? If I find just the filter without the cap attached it works fine..
Any suggestions or comments appreciated !
Thanks
Old 05-06-2013, 10:07 AM
snakedoc's Avatar
snakedoc
snakedoc is offline
most of the filters with the caps are hard to seal, i just get the filter and reuse the cap.
Old 05-06-2013, 11:42 AM
Brother Les's Avatar
Brother Les
Brother Les is offline
x2.... tell the guy at the auto store... I have a cap...filter only please.
Old 05-06-2013, 11:53 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Thanks
Here is a source for just the filter element. I usually order 3 or 4 at a time and keep them on hand.
Racor PFF4596 Replacement Fuel Filter Element for 1999-2003 Ford 7.3L Diesel
If you must use the integrated cap/filter design. The Baldwin filter seems to fit well. PF7698
Old 05-06-2013, 11:55 AM
snakedoc's Avatar
snakedoc
snakedoc is offline
bob is where is oder mine by the case it makes shipping cheaper.
Old 05-06-2013, 03:16 PM
lght1's Avatar
lght1
lght1 is offline
Hi
Since i got this L'99, I have had miserable luck with Motorcraft lids/gaskets sealing. The best so far, has been the combined cap and element from AZ.
Although I saved the MC lid, I likely wont go that way again based on my own experiences.
Old 05-06-2013, 03:32 PM
Studawg's Avatar
Studawg
Studawg is offline
Thread Ender
When I got the truck it had one of those aftermarket filter/lid combos, I didnt have a problem but when I changed it, I bought a new OEM lid and OEM filter and have been replacing with the OEM filter ever since, no problems.
Old 05-06-2013, 06:13 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Originally Posted by lght1
Hi
There is no difference in early and late 99 fuel bowls.
The Motorcraft filter is the best filter to buy IMO, Baldwin would be an acceptable substitute. Racor manufactures the OEM filters so thy would also be okay. But the 'AZ' brand is probably a far inferior product as is typical with AZ. I know it's not as good as Motorcraft. Also, avoid WIX or Napa fuel filters as they are very sub-standard in this application. They filter far less and don't have effective water separation.
There is much more to a filter than how well it fits. We learned this with the K&N fiasco.
For what it's worth, I have never had a problem with my MC lid and replacement filters. The O-rings are a pain at first but you get used to it. A properly tightened lid is all you need worry about.
Old 05-06-2013, 06:39 PM
MTDewX's Avatar
MTDewX
MTDewX is offline
custom wrench
I havent bought a strap wrench thingy yet so I improvised. worked so far.
so far I have been lucky on my lid with re-using it.
they sure can be a pita
Old 05-06-2013, 07:31 PM
Shake-N-Bake
I am curious.....does everyone use a tool to remove and install their fuel bowl lid? I have always just screwed it on hand tight and remove it by hand. I probably used a tool to tap it counter clockwise to remove it in the early days but for the last couple hundred thousand miles I just tighten it by hand and it's been sealing just fine.
Old 05-06-2013, 08:10 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I use a flat head screw driver and a hammer to give it a few insurance taps.
Old 05-06-2013, 08:13 PM
twg1966's Avatar
twg1966
twg1966 is offline
Trying to Gain Knowledge
I Use the handles of a large pair of pliers to twist on it with no issues.
Old 05-06-2013, 09:35 PM
lght1's Avatar
lght1
lght1 is offline
Hi
Motorcraft did not work for me, hence I went to something else. If you google, MC has proven to be a leaker for some people. I think the beveled gasket is to blame.
Old 05-07-2013, 09:10 AM
MTDewX's Avatar
MTDewX
MTDewX is offline
I have used several ways. but seem to bugger things up when I do the screw driver or wrench way.
hand tight dont work for me. mine will leak.
steinernm
07-22-2018 07:42 PM
kelsey344
12-05-2011 06:32 AM
todd230
11-04-2007 02:26 PM
Hotwheelbill
04-20-2006 05:22 AM
joe Kikiwai
02-02-2006 02:57 AM
Quick Reply: fuel filter
