steering wheel removal
Old May 5, 2013 | 09:54 PM
hoagie48's Avatar
hoagie48
How do I remove the steering wheel because it don't have bolt holes for a puller? It's on a 48 F6.
Old May 5, 2013 | 10:16 PM
bobj49f2's Avatar
bobj49f2
Some of the trucks seemed not to come with tapped holes. If yours don't have the fine thread 5/16" hole you'll have to tap them. It's not hard. Also, insert a bolt into the column shaft to use the push the puller threaded rod off of. If you don't you run the chance of mushrooming he steering shaft and make it extremely hard to thread the nut back on.
Old May 6, 2013 | 12:22 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Loosen the nut to the top of the shaft, place your knees behind the wheel pushing it up the shaft, strike the shaft with a brass drift while holding up pressure and the wheel will pop up to the nut.
Old May 6, 2013 | 01:38 AM
aussiecowboy's Avatar
aussiecowboy
You make it sound so easy
Old May 6, 2013 | 08:01 AM
abe's Avatar
abe
I removed the wheel on y 54 without a puller. I wiggled and pulled on the wheel and pulled with my ha D's as I had my feet up against the floor board to help pull. After a while it came off. This was the first to e I had it off since I owned it in 1977 and probably the only time it was off in 55 years. But make sure to leave the nut on a few turns or you will get the steering wheel in your face...
Old May 6, 2013 | 01:59 PM
truckeemtnfords
It is easy , as long as you leave the nut on so you don't mess up the threads and your teeth
Old May 6, 2013 | 05:24 PM
49m47's Avatar
49m47
I tried the knee and wiggle technique but it didnt work for me. I went a head and drilled and tapped 2 holes. It only took a few minutes.
Old May 7, 2013 | 01:42 AM
truckeemtnfords
The wiggle has never worked for me hence the brass drift to break the grip between the shaft and wheel splines.
Old May 7, 2013 | 07:11 AM
johnnydevil55's Avatar
johnnydevil55
when i did my fairlane i used a puller and it would not come off. i was bending the 5/16's bolts. i used PB blaster, hammers and torches, etc.. so it figures when i pulled the steering wheel of my rusty/rotted customline parts car that it popped off as soon as i started tightening the puller..some are easy, some are stubbon. i'll be pulling my wheel off my 51 f1 so hopefully i'll have no problems.. glad to see you got yours off!
Rasputin53
Apr 2, 2014 11:24 AM
llacours
Aug 21, 2013 06:36 AM
Christopher2
Jul 28, 2012 11:01 AM
Schoonie48F2
May 30, 2004 07:58 AM
q_ball
Mar 8, 2001 04:02 AM
