351C or 351M
Old Sep 21, 2016 | 06:05 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Originally Posted by 351mINmy93
sorry but cleav and mod use diff heads mod had 400 head made it a decompressed 400 that made it a 351plus the mid has a big block bolt pattern for bellhousing of tranny
Are You speaking English ?
Old Sep 21, 2016 | 09:49 PM
Nothing Special's Avatar
Nothing Special
Keep in mind that this thread was resurrected from 3 years ago.
Old Sep 21, 2016 | 10:11 PM
ctubutis's Avatar
ctubutis
And was resurrected by a newbie who seems to have joined exclusively to submit those two posts, it looks like he's basically trying to say that Franklin2 is wrong and he's right - in exceedingly poor, difficult-to-understand English - in a 3yo thread.
I'll delete his posts and all this chatter if it's OK with you guys, let me know.
Old Oct 2, 2016 | 01:53 PM
Mad tiki's Avatar
Mad tiki
Originally Posted by George Fletcher
I'm wondering if my pickup has a 351 Cleveland or a 351 Modified. All along I have been told its a Cleveland and I have been ordering parts for a Cleveland and they all fit and work properly, but when I took my starter out to put it in my new 75 F150 the casting number on the engine block was D7TEA35 and above that upside down was 9819. I searched around on the internet and i can't find a D- code 351 Cleveland. I can find D-code 351 Modifieds. I've had 6 mechanics tell me its a cleveland by measuring from the water pump to the intake, counting valve cover bolts, the size and many other things. I'm really confused here and I'm not sure what to do all of the Cleveland parts I've been ordering have fit just fine and it operates just fine. Were they all wrong? Any suggestions on this?
Easiest and fastest way to tell a Cleveland from a 351m or 400 is the fuel pump. The mounting bolts are top and bottom. The others are side by side. Basically the Cleveland is a small block with Big Block Heads. Its actually a great motor. Its what was in the Pantera.
I have a 351C with C-6 Trans (which was offered in small or big block pattern) in my 56 F100. Downside to the C is swapping a 2 BBL to 4BBL. You either have to buy an aftermarket intake or change out the entire top end of the motor. (Heads and intake) if wanting to use Ford parts.
BTW, they can be easily built to rev to 7k with no issues, so although a very limited production and rare motor, they are pretty bad ***.
I tend to like the oddball motors. I like openeing my hood at a show and showing something out of the ordinary. Downside to that is cost. Parts are always way more expensive.
My Headers for my 67 Cougar with factory S code 390 just ran me 700! As apposed the a 302 would be about 250-350.
Old Oct 2, 2016 | 03:04 PM
ctubutis's Avatar
ctubutis
ALL of the 335-series engines - 351M, 351C, 400 - use a fuel pump with the vertical mounting bolts; the V8 Windsor engines (and all other engines, 335 is the only one to use this configuration) use side-by-side.
Old Oct 2, 2016 | 03:27 PM
Mad tiki's Avatar
Mad tiki
My mistake. You're correct. Now that im thinking about it, it was the difference between the C and W being the fuel pump bolt pattern.
Thanks for clarifying
Old Oct 2, 2016 | 04:13 PM
FuzzFace2's Avatar
FuzzFace2
I want to say I remember something about number of valve cover bolts or was it intake bolts? between the motors?
Dave ----
Old Oct 2, 2016 | 04:20 PM
ctubutis's Avatar
ctubutis
Dave ----
That works, too; 335-series use 8 I believe, Windsors use 5 or 6 (I forget).
Old Oct 2, 2016 | 06:15 PM
Franklin2's Avatar
Franklin2
Easiest way to tell a 351c from a 351m/400 is the casting step behind the distributor hole; The 351m/400 has a step, the 351c is flat and level to the intake end seal area.
That's one thing I will knock Ford for; They changed their minds too many times, and when they did nothing was compatible. They are still doing it too.
Old Oct 2, 2016 | 06:25 PM
Mad tiki's Avatar
Mad tiki
Agreed. Thats always been their biggest downfall. And waste of huge profits. Instead of perfecting existing parts, they would scrap just about everything and start over from scratch.
GM was genius with the 350. Just kept tinkering till they got it right.
But with that said, I will never under any circumstances put a GM motor in any of my Fords. Im of the mindset that Fords engineers are better. Why? Simple. Fords smaller 302 out performs GM's 48 cubic larger 350. Plus it was Ford that slapped Ferraris ***. Not GM 👍🏻
Old Oct 2, 2016 | 06:32 PM
Franklin2's Avatar
Franklin2
I disagree with that. Ford's small v8's and the chevy v8's are very similiar in design. They both can be built for power. Ford's downfall was always the heads. Yes, they made some decent heads, but the majority of the heads that they put on their everyday cars are no good for making horsepower. If you want to build a Ford engine, the heads are the first thing to go or be modified.
Old Nov 27, 2025 | 06:55 PM
Chris Tracy's Avatar
Chris Tracy
1st Gear
Stumbled across this old thread. I’m building a 400 with 351C 4bbl heads to put in my 1979 F150 4x4 with power steering and AC.
Anyone know of a Frankenheader that will fit without too much modification?
Old Nov 28, 2025 | 02:05 AM
  #28
KULTULZ's Avatar
KULTULZ
Arrow
351C/351M/400: All have 8 valve cover bolts per side. There is no timing cover per se, just a flat engine front cover plate.
The fuel pump bolts to the left (drivers) side of the engine block using a 6 & 12 o'clock bolt pattern, the only V8 fuel pump to have this pattern, as all the others are at 3 and 9 o'clock.
351C = 1970/74 Ford/Merc Passenger Cars/Ranchero's only.
351M = 1975/79 misc FoMoCo Passenger Cars; 1977/79 F100/350; 1978/82 Bronco; 1980/82 F150/350.
400 = 1971/79 misc FoMoCo Passenger Cars; 1977/79 F100/350; 1978/82 Bronco; 1980/82 F150/350.
How could 9819 refer to September 19, 1979? What does the 8 refer to?
This would be correct: 9J19 = September (J) 19, 1979 (9). A = January, M December, the letter I is skipped.
I suspect the 8 is actually a B (February) ~ 9B19
Many M-block (351M/400) engine blocks have a 5/8" tall raised web just left of the distributor hole, on the top of the block. However, not all M-blocks have that web, as this photo (and the previous photo) of a 1978 MCC block shows.Some people say you can distinguish an M-block from a 351 Cleveland block by that web. It's true that no 351 Cleveland blocks have that web, but not all M-blocks do either. While presence of the web rules out a 351 Cleveland, absence of the web does not rule out an M-block.
SOURCE - M-Block 351M/400 Photo Archive
Old Nov 28, 2025 | 06:33 AM
  #29
Franklin2's Avatar
Franklin2
The 351c is shorter and a little bit narrower than the 400. I would try headers for a 1979 truck with a 400. I would think the clearance would be fine around the frame up front, but I am not sure about clearance to the bellhousing. I would see if a local parts store can order them for you, so you can easily take them back if they do not fit.
Old Nov 29, 2025 | 01:11 AM
  #30
KULTULZ's Avatar
KULTULZ
Arrow
https://sandersonheaders.com/product...rd-351c-m-400/
Super Econoline
15
Oct 25, 2012 09:35 PM
Fix_Or_Repair_Daily
Jan 6, 2011 10:11 PM
ford0625
Dec 22, 2009 03:14 PM
slmd350
Nov 5, 2003 04:57 PM
