1978 - 1996 Big Bronco
Drivers Window
Old Apr 15, 2004 | 11:38 AM
buckeyebronco's Avatar
buckeyebronco
Drivers Window
My drivers side door window doesn't work but the passenger side one does work from the drivers side. Is the switch shot or is there a little trick anybody knows of to fix it?
Old Apr 15, 2004 | 12:50 PM
ANdrewdrice's Avatar
ANdrewdrice
it is probably the motor. check the power plugs on the motor or test the motor to see if it is totally blown
Old Apr 15, 2004 | 02:19 PM
90ebbronc's Avatar
90ebbronc
And If you can hear the motor run, then its the great little plastic gears inside the motor that Ford came up with. Why plastic i have no idea. All i know is that im about to have to replace three motors. Back window, passenger side window, and now driver side window is getting slow, lol.
Old Apr 15, 2004 | 05:03 PM
buckeyebronco
How do you get the old motor out? I think its blown because there is voltage in the power wires when I push the button.
Old Apr 15, 2004 | 09:19 PM
ohrtman19's Avatar
ohrtman19
tap the motor with a hammer lightly without hitting the glass and see if it frees it up and it will work for a very short period of time ( maybe 2-3 days ) but youd be better off buying a new motor or getting new brushes and rebuilding the motor.
Old Apr 15, 2004 | 11:01 PM
ANdrewdrice
to get the motor out, cut a bigger hole in the door if you have to, but dont break the glass. and drill out the rivits, without breaking the glass. hold on to the window and dont let it fall down because it will break; let it down easy. Then re-attach put the new motor in and bolt it in with lockwashers and screw goop so the nuts dont fall off. its pretty simple if you understand the basic (really basic) way mechanical stuff moves and works.
Old Apr 16, 2004 | 12:23 AM
90ebbronc's Avatar
90ebbronc
And if he didnt mention it, dont break the glass .
ohioexwner
Jan 27, 2015 11:00 PM
fdesorme
Escape & Escape Hybrid
Sep 7, 2010 07:05 AM
gmbtowing
2004 - 2008 F150
Sep 7, 2009 01:29 PM
BlackFX4Screw
2004 - 2008 F150
Feb 20, 2007 11:23 AM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
