Bronco II Ford Bronco II
Washer moter
Old Nov 30, 2006 | 08:49 PM
docman's Avatar
docman
Washer moter
Hi
I have a 1987 bronco 11 and I have changed the motor for the front washer but the back still won't work. Is that a different motor for the rear washer.
Thanks Docman
Old Dec 5, 2006 | 06:53 PM
clunker86's Avatar
clunker86
i believe there is a different pump for the rear. i had a 89 and i know you pure the washer fluid in the rear. you should see it right by your break light when you open the back gate up.
Old Dec 5, 2006 | 08:59 PM
docman's Avatar
docman
Thanks for the information on the washer pump. I will look for it in the morning.
Old May 5, 2013 | 06:24 PM
Eileen Pike's Avatar
Eileen Pike
1987 Bronco II V6
Help Me if You Would Please! I am trying to deal with an Electrical issue. Fuse Links. I am Not Familiar with the motor that is in My Bronco! It seems Backwards to Me! I am a Good Mechanic but I have not seen this one before! Not to mention that it has been awhile since I have been under any Hoods!
Well, Turns out it was the Electronic Brain that sits under the Distributor. Darn Thing Shorted out and needed to be Replaced !
Chea77F150
Dec 21, 2011 04:26 PM
Escape055
Escape & Escape Hybrid
Nov 14, 2009 09:35 AM
projectdagger
Mar 9, 2009 04:57 AM
philipk
Dec 25, 2008 09:55 AM
eclectix
19
Aug 18, 2003 12:50 AM
