brake booster
Old Apr 16, 2008 | 09:26 PM
rmalottwtes30's Avatar
rmalottwtes30
brake booster
How do you test for a bad brake booster? I am suspecting mine is bad.
My brakes are spongy. When your sitting still you can push the pedal down far then pump it up and the pedal gets hard. Is that suppose to be that way?
Old Apr 16, 2008 | 09:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
With the engine off, it is normal. Every time you press the pedal with the engine off it releases the stored up vacuum from the booster.
All the booster is for is to aid in pressing the brake pedal.
Old Apr 17, 2008 | 06:08 AM
ri_truck_guy's Avatar
ri_truck_guy
With the brake warning light issue and dirty fluid in your master cylinder, I strongly recommend you resolve those issues before you start on your master cylinder....spongy brakes can easily be related to those other two symptoms. You've got several different strings going, all running in circles around these symptoms. Resolve the obvious. If you check your proprtioning valve safety switch, as has been recommended to you several times now, you can narrow the focus greatly. The discolored fluid and spongy brakes only reinforces the need to do that check first. If disconnecting the switch turns the brake warning light off, you likely have a pressure problem somewhere downstream in the system. Likely a leaking wheel cylinder, or leaking brake line. Either of those will cause the fluid to discolor. You're getting good advice on here.
Old Apr 17, 2008 | 04:43 PM
rmalottwtes30
This weekend were going to flush out the whole brake system. Actually I think I told you wrong its the resivor for the front brakes that are all dirty looking, we have never messed with the fronts, although the PO put on new brakes, and rubber hoses, and rotors.
Today I also noticed you can also push the brakes to the floor then keep pumping to pump them up to be stiff. Is that also normal with it running, or is there air in the lines? We inspected all the lines and there is no fluid seeping out anywhere.
Again thinks for the advise, and remember im not to knowledgeable about diesels yet.
Old Apr 17, 2008 | 04:53 PM
81-F-150-Explorer
No that is certainly not normal at all.
If it's the front brakes that looks dirty, then it could be the calipers are leaking. Or you got a bad master cylinder. Or that there is ai or contaniments in the brake lines.
This is why your Brake warning light is on. you have brake faliure to one of the axles. I would guess the front, because of the discoloration of the fluid.
Flush the system with clean fluid, check it for leaks, etc...
Above all don't drive t untill the brakes are corrected.
Old Apr 17, 2008 | 05:04 PM
rmalottwtes30
Thanks 81f150, you've helped me a lot and appreciate it a lot.
I guess it calls for taking the front tires off now. Ive never messed with front brakes on it yet. I will in doubt check closely for leaking calipers or and spots in the lines. If I don't find anything Ill go out and get a new booster.
How would I go about getting contaminants out of the lines? or would replacement lines be on order?
I don't plan on getting it on the road yet, All we ever do is when we work on it is drive it up the road to check things and thats about it.
Thanks again
Old Apr 17, 2008 | 05:49 PM
85e150's Avatar
85e150
Fluid gets contaminated in the calipers and wheel cylinders, as regardless of the condition of seals, there is some introduction of air and/or moisture to the system through the seals and movement of the parts.
Flushing the system while bleeding the system will get rid of the contaminated fluid and any air as well.
You can usually bleed without pulling wheels, but if you need to inspect wheel cylinders, you have no choice. Some calipers can be seen clearly enough w/o removing wheels.
Old Apr 17, 2008 | 07:13 PM
ri_truck_guy
What I was trying to say was don't worry about the brake booster now...not the master cylinder...guess that's what I get for trying to write at 6 in the morning....sorry about the confusion.
Old Apr 17, 2008 | 08:15 PM
Franklin2's Avatar
Franklin2
You have to remember you have a diesel. For your vacuum booster to work, it needs vacuum, and the only way you get it with your diesel is the little vacuum pump under the alternator. It may be getting weak, you may have a leak in a line somewhere, and remember you are probably just idling when you are doing this, so it may be the fact it can't keep up. Rev the engine while doing it and see if it takes longer for it to get stiff(run out of vacuum).
Old Apr 17, 2008 | 10:28 PM
82f3504x4's Avatar
82f3504x4
it dosent sound like your booster is out. when it goes out it is VERY hard to push the pedal, or you will hear a hissing leaking sound like mine is currently making
