I unplugged the sensor and yep there is oil present. It is running fine unplugged. I will chase the wires to check for chaffing just to be sure. Thanks all for the thoughts and if there are any more problems I will resurrect this.
BTW, I should have mentioned that the oil is fresh and full.
Thanks again, this site continues to deliver, even if you don't get your stuff when you re-up......
Hey If the Harness is bad you can buy a new harness and Wire it in and put a new plug on the wires.. U can pick up the harness.. If your going to buying new sensors dont do what i did buy cheap parts buy oem save u the hassle i went through.. GOOD LUCK
