Performance chip
Old Apr 25, 2013 | 09:20 AM
FordYoungGun35's Avatar
FordYoungGun35
Performance chip
Has anyone tried a performance chip on these trucks? mine is in the sig, its a mass air motor, is it worth it? these are the 3 ive found http://www.summitracing.com/search/m...t?keyword=chip
Old Apr 25, 2013 | 09:49 AM
White 97 xlt's Avatar
White 97 xlt
Sure does seem like a very expensive way to bump the timing up 3 or 4 degrees.. From what every one on this forum says, that's about all the so-called performance chips do for these trucks. Same thing on the throttle body spacers.... Making the intake air go another 1/2 inch or so isn't going to do a thing....
Do a search,, you will see what I am talking about...
Old Apr 25, 2013 | 12:02 PM
Encho's Avatar
Encho
The Southernmost Mod
Basically: don't waste your money on a chip... Btw, did you ask this before?.
Old Apr 25, 2013 | 12:14 PM
Bob Gervais's Avatar
Bob Gervais
Mail-order tuning isn't going to give the same results as a dyno tune will. These chips can firm your shifting, change shift points, remove speed limiter, change timing curves and MAF transfer, as well as injector pulse.
But....
Buying one stock off the shelf may make a noticeable difference, but not the optimum difference for your particular vehicle.
A dyno tune is much more accurate, however if you don't have a lot of engine mods, it's probably money better spent elsewhere on your truck.
Old Apr 25, 2013 | 12:33 PM
DIYiT's Avatar
DIYiT
TEKTON 5850 Distributor Wrench Set, 2-Piece - Amazon.com TEKTON 5850 Distributor Wrench Set, 2-Piece - Amazon.com
You can use this to do the same thing as any "chip" (advance the timing)
Old Apr 25, 2013 | 12:56 PM
Fordman96's Avatar
Fordman96
I can't see the year on my phone, but quarterhorse makes a good tunable programming chip. Plug it in and you can adjust it yourself like dyno testing.
Old Apr 25, 2013 | 02:43 PM
blue924.9's Avatar
blue924.9
as others have said dont waste your money on a chip, jets piggyback module is also a no go
ercthgreat
Apr 1, 2012 11:08 PM
86moneypit
Computer Chips & Tuners
Dec 23, 2004 09:09 AM
RotGutBottom
1997 - 2003 F150
Mar 16, 2002 11:10 PM
billbain
Nov 29, 2001 05:16 PM
traildawg
Jun 2, 2001 07:27 AM
