EGR decisions
Yeah, get to know Riffraff and Tousley. I spoke at length to the parts guy at Tousley, they know their sh_t and are extremely helpful. Oil cooler there was a good price but I ended up with a factory sealed one off ebay for a tad over 200.
You're doing an EGR delete but I went HD cooler instead (Kalifornia). Best deal was a BD Diesel Performance unit from Xtreme Diesel using the 10% discount code DIESEL10. It's $224 to my door...
Shop til you drop!
Now let me get this straight, because I don't even know what they are in the first place, the stand pipes and dummy plugs, I need 2 of each correct?
Yeah being that the cap is 5 bucks I'll just order a new one haha, I'm going to get a new degas bottle as well because mine looks like **** has been sitting in it for years. I see the blue spring from RiffRaf is like 80 bucks with the cover, and 40 without. Is there a way to tell if the cover is cracked without tearing the motor apart? I have no idea where it's located haha.
Do a search for the blue spring install - several posts with pics and everything. I will say though - if you do not have a duel leak and you are reasonably careful with the work, most people do NOT need the cover.
<TABLE style="WIDTH: 432pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=576 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 165pt; mso-width-source: userset; mso-width-alt: 7822" width=220><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=340>Hose: coolant degas bottle to the engine front cover</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 165pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 width=220>5C3Z-8075-CB</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 432pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=576 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 165pt; mso-width-source: userset; mso-width-alt: 7822" width=220><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=340>New degas (coolant overflow) bottlecap</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 165pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 width=220>9C3Z-8101-B</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 432pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=576 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 165pt; mso-width-source: userset; mso-width-alt: 7822" width=220><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=18 width=340>Kit for dummy plugs and stand pipes (late 04-07):</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 165pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=220>6E7Z-9A332-B</TD></TR></TBODY></TABLE><TABLE style="WIDTH: 432pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=576 x:str><COLGROUP><COL style="WIDTH: 255pt; mso-width-source: userset; mso-width-alt: 12088" width=340><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 568" width=16><COL style="WIDTH: 165pt; mso-width-source: userset; mso-width-alt: 7822" width=220><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 255pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=340>STC Kit (05 and up ONLY)</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 width=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 165pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 width=220>4C3Z-9B246-F</TD></TR></TBODY></TABLE>
The Ford 6.0 STC HPOP Fitting Update Kit 4C3Z-9B246-F contains:
* 1 Support Bracket
* 1 Hydraulic Pump Seal Kit
* 1 Branch Tube Adapter - Male
* 1 HPOP Adapter Fitting - Female
* 2 M6 X 35 mm Branch Tube Bolts
* 2 M8 X 60 mm Pump Bolts
* 1 M8 X 45 mm Pump Bolt
* 1 Support Bracket
I'll probably end up getting the turbo feed and drain tube anyways, if they're not too expensive. As far as the blue spring, I'll just take my chances and get it without the cover, worse comes to worse I'll just order the cover if it's bad.
I ended up calling Tousley because even with part numbers I couldn't get some and then there were some very interesting names for parts (like the Dummy Plug/Stand Pipe kit is called something or other fuel tube. Just ask for internet sales and they can do it all over the phone at the same price they have on the internet.
On the Blue Spring: I think we missed giving you an answer to your Q; you know where your engine mounted fuel filter is? If not it's in front of the oil filter canister -- anyway on the front of the fuel filter is the cover you remove to install the Blue Spring. Take a look at the cover and below it and see if there's any wetness that is diesel fuel. You can check Tousley's price, but I think Riffraff was the best total deal when I was shopping -- plus they're also good peeps...
You do know that all these parts your getting take some time/skill to install, right? With coolant flush somebody that knows what they are doing is in the 16-20 hr range. I also opted for new valve cover gaskets since those have to come off to get to the dummy plugs/stand pipes (the valve covers). They are a reusable gasket but I've had a leak there before and want it that way after (no leaks)...
And yeah, I'm not sure what I'm going to do yet as far as the install. Might end up having someone do it so I don't mess anything up.
IPR EGR Valve Bypass Test Plug Ford 6.0 Powerstroke F250, F350, F450, F550 International VT365
). Just follow the directions in the tech folder and break the fuel line loose with TWO wrenches. Now me, since I always find the hardest way to do everything, instead of pulling the fuel line I took the bolt out of the clamp that holds the hard fuel lines to the head (a real b_tch to do, but it worked and no broken cover or leaks after...I'm taking the route of having someone else do it: bad back in two places and probably lacking some tools, plus after watching some of the You Tube vids on the job(s), there definitely are some tricks, and lots of stuff coming off that needs to back on in the right order. I spent some time asking for shop referrals and then interviewing the shops before I chose the one I'll use. Most parts are in and Dan-the-man goes under the knife 5/13...
I installed the Bullet Proof Diesel Oil System and EGR cooelr a few months back. At that time, I wasn't sure if I should delete it or not. I thought I may tune it out later and if I ever had to undo it for emissions or whatever reason, it would be easier. I haven't done the tuner yet, but was curious since I have the BPD EGR cooler, if there was a cleaner EGR valve delete then just a cover and leaving valve in the valley.
Still not sure if the cooler needs to be done or not, I'm off Friday so I plan on trying to figure that out then. Still searching around for the best price on a cooler though just in case. On Tousley I can't seem to find the cooler there, when you type in oil cooler it just comes up with the gaskets, and a trans cooler. I typed the part number for the oil cooler in and it came up with something for 277, trying to find it in the search without using the part number to see if it comes with gaskets or not. Might just be something I have to call on.
