If your icp koeo voltage is 1.14, then you probably have a bad connection at the ICP plug. You can wiggle the plug and monitor the voltage to be sure that is the problem. If it is, you can get the pigtail from the dealership.
Did the wiggle test and there was no change on the ICV.
