6.0 starting issues
Old May 10, 2013 | 11:44 AM
  #31
ElPasoRedNeck's Avatar
ElPasoRedNeck
Sorry I'm not seeming to be very active, funds are not in my favor currently. Soon enough my VA disability will hit so that will no longer be an issue, and i'll be bothering everyone a lot more as I transform my 250 into a monster.
Old May 17, 2013 | 09:10 AM
  #32
ElPasoRedNeck
Originally Posted by Misky6.0
Did you change oil filter recently?
Do you use ford oil filters and know you have a oem oil cap? Aftermarket filter and caps usually don't work properly and let oil drain without being filtered. Lots to read on fte, hope you get more help..
if the low side looses pressure the hpop can't build pressure to start. Not sure, just throwing it out there.
Hit the nail on the head (i've just been broke) got the non OEM cap replaced with an OEM one yesterday new oil and filter (Delo 400 and FL2016) ICP still isn't spiking like it should, I didn't record my values last night while i was out there but it took it about 10-15 seconds just to get over 200. I am just greatful that yall are helpin me out with all of this, progress is progress right
Old May 17, 2013 | 11:07 AM
  #33
Per4mance's Avatar
Per4mance
Your moving in the right direction now get some values posted and we can get you moving ahead.
Old May 17, 2013 | 11:21 AM
  #34
ElPasoRedNeck
Should i Get the different values posted before i go pick up a new ICP? I called the dealership and i can get one this afternoon for about 150.
Old May 17, 2013 | 11:32 AM
  #35
Per4mance's Avatar
Per4mance
Yes, just don't throw parts at it lets get to the root of the problem and save some money so you can spend it on the RIGHT things before you make it a monster
Old May 17, 2013 | 11:38 AM
  #36
ElPasoRedNeck
Ya its what i get for buying the truck from where i did, but it's giving me the practice on nonmilitary diesels
Old May 17, 2013 | 03:59 PM
  #37
ElPasoRedNeck
KOEO
icp 0
ipr 14.8
ficm main power 48.5
ficm logic power 10.5
cranking
icp 74 after about 30 seconds
ipr 84.7
ficm main no change
ficm logic dropped to 7.5
Old May 17, 2013 | 06:13 PM
  #38
Per4mance's Avatar
Per4mance
Disconnect the ICP and see what the IPR says sounds like you have a high prresure oil leak thst will give the compu false value for the ICP
Old May 17, 2013 | 06:17 PM
  #39
Per4mance's Avatar
Per4mance
I'm hoping someone with better typing skills than me will chime in cause I can't type as fast I think
Old May 17, 2013 | 10:32 PM
  #40
ElPasoRedNeck
Should i go ahead and get the stuff to do the air test through the icp port? Also i disconnected the icp yesterday to have the pcm use the default settings and it was still a hard start. The truck will start it just takes entirely too long, i'm not wanting to buy a starter in the near future due to a hard start situation.
Old May 17, 2013 | 11:29 PM
  #41
BLADE35's Avatar
BLADE35
Where is the ICP sensor on this truck??? Valve cover or under Turbo??
Post ICPV at KOEO
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
Post V-Ref KOEO and Cranking and at Idel next time it runs
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
Also Post
VOLTS (I suspect low volts from so much cranking so Keep charger on it)
RPM while Cranking
Old May 17, 2013 | 11:32 PM
  #42
BLADE35's Avatar
BLADE35
Pull the cap offf the Oil Filter and Crank see how fast it Fills May need to hold the drain down while you do this
I suspect your ICP sensor is in the valve cover
When you do get it to run does it run Good or Choppy or ????
If you can get it to run get it Hot EOT at 190* and Post Low Idel and High Idel (2500RPM) values for
ICP and IPR%
Also set the SGII to Update rate of FAST
Old May 18, 2013 | 12:55 AM
  #43
ElPasoRedNeck
i'll get all of those posted this weekend blades, thanks
Old May 21, 2013 | 08:08 PM
  #44
ElPasoRedNeck
KOEO
ICV 1.30
v-ref 4.97
167 was the highest rpm
and no change on the other two while cranking
Old May 22, 2013 | 12:27 AM
  #45
04badford's Avatar
04badford
Originally Posted by ElPasoRedNeck
KOEO
icp 0
ipr 14.8
cranking
ipr 84.7
ficm main no change
you only had 74 at cranking should be at least 540+ If your going for a ICP Riffraff has the better price I just payed 170 and some change didnt have time to shop .
