I got a price of $150ish before taxes from the dealership, but thats because i get a veterans discount. I'm going to go pick it up today since the truck finally threw the P2285 code, for whatever reason either my SGII didnt catch it or the truck wasnt showing it.... IDK
This sounds very familiar, just for ha, has disco the batteries and turn the lights on for a half hour. Reconnect and try to start it. Worked for me no problems since
ah so i am low then. guess i'll have to get my ficm sent out to Ed, that a lot of guys talk about, get it rebuilt and upgraded. yes i checked the logic fuse and its good
What were your FICM volatges KOEO and cranking? Do you have any gauges that read live data like scan gauge II or one of the smartphone apps like dashboss for IOS or torque for android? They are an absolute must have and are required for diagnosing these trucks? Do you have any DTC's ?
If your icp koeo voltage is 1.14, then you probably have a bad connection at the ICP plug. You can wiggle the plug and monitor the voltage to be sure that is the problem. If it is, you can get the pigtail from the dealership.
