Sponsored by: Real Truck
Driving lights
Old Apr 23, 2013 | 12:39 PM
big-head's Avatar
big-head
Driving lights
Looking to brighten up my night time driving. Want something really bright. I have a 07 F250 4door 6.0. Question is do I ad lights to my ranch hand ( worried bout looks) or do I update my factory headlight bulbs. Get me some help. Mainly want to see deer etc in hwy
Thanks
Old Apr 23, 2013 | 12:45 PM
Firekite's Avatar
Firekite
Adding lights is definitely the best and most legal option. What's your budget?
Old Apr 23, 2013 | 01:07 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Light bars are really popular on the 2011+ trucks, if you could mount that to your grille guard it would definitely be a huge improvement over just the headlights. Pricey, but dam they're bright.
https://www.ford-trucks.com/forums/1...light-bar.html
I went from factory bulbs to Silverstars. No noticeable difference. Clipping a wire to run the fogs and brights at the same time made more of a difference.
Old Apr 23, 2013 | 01:27 PM
big-head's Avatar
big-head
Really never thought about $$$ just want something that will be bright and cost within reason
Old Apr 23, 2013 | 02:16 PM
Firekite's Avatar
Firekite
Definitions of "within reason" vary wildly. That's why I asked.
Old Apr 23, 2013 | 02:29 PM
BigBlockF350's Avatar
BigBlockF350
I'd add a bar to the front and mount lights on it. Are you looking for driving lights that you can have on all the time or really bright hi-beams that you can wire into your hi-beam switch (through a separate relay)?
Also, you can swap your regular bulbs to HIDs to give you better light. I don't particularly like these because it makes me think of all the modded ricer cars, but they do give off good light.
Old Apr 23, 2013 | 02:30 PM
bikerman2299's Avatar
bikerman2299
This is what I put on my '11 250 gasser. Since I live in deer country I wanted a wide beam setup. They are amazingly bright, and not horribly expensive. If you have upfitter switches they are a breeze to wire.
KC HiLiTES 634 Daylighter - 6 In Black 130w Driving Beam Off Road Light System (Pair) : Amazon.com : Automotive KC HiLiTES 634 Daylighter - 6 In Black 130w Driving Beam Off Road Light System (Pair) : Amazon.com : Automotive
Old Apr 23, 2013 | 02:34 PM
bikerman2299
This is what they look like.
Old Apr 23, 2013 | 02:53 PM
big-head's Avatar
big-head
Lights
Where is this wire to "clip". Running both brights and fog is something I would like
Thanks.
Old Apr 23, 2013 | 02:57 PM
big-head's Avatar
big-head
Lights
What about the "long range" package just like these. Are yours wide and fairly long or just wide ?
Old Apr 23, 2013 | 02:58 PM
big-head's Avatar
big-head
Lights
Don't mind spending two hundred dollars or so
Old Apr 23, 2013 | 02:59 PM
texastech_diesel
Token Redneck
Thanks.
Here's the quick and dirty:
https://www.ford-trucks.com/forums/5...info-here.html
Pull one wire from behind the fuse block, ground it to the body, and done.
And here's the reason and theory behind it:
http://www.ssdiv.com/fogfix.html
Basically the high-beam indicator lamp on the dashboard doubles as a trigger that kills the fog relay. You're interrupting that signal, so the fogs are never shut down. So it's harmless, you aren't messing with any programming issues. I've run my truck this way since it was almost new.
bikerman2299
I was thinking about putting these on my truck when I got back. But I wasn't thrilled with the prices.
Ford Super Duty LED Light Kit
Old Apr 23, 2013 | 03:02 PM
bikerman2299
I wired mine independently, and hooked them up to an upfitter switch. That way I didn't have to worry about tapping into my factory wiring harness. They will cast light well beyond my high beams and they will cover a two lane road from side to side plus some.
Old Apr 23, 2013 | 03:32 PM
big-head's Avatar
big-head
Lights
S&S Diversified
Thanks a ton. This will be my next weekend project.
