Driving lights
It sounds like you're trying to mount the lights as though they were sideview mirrors, sticking out from the side of your brushguard like ears. Surely not...
If your brush guard has the metal mesh, then Ranch Hand sells light brackets for that. Otherwise they should generally be mounted either up or down through a light tab or maybe tube clamps like these. See how bikerman2299 did his? And then see the Ridgeline for an example of them mounted upside down (must modify the light as per PIAA instructions before you do that).
There are lots of ways to trigger them, but basically you need to use a wire that's hot only when the high beams are on as the switching source for your relay (NOT to power the lights directly).
The Amazon page I linked him to originally is a single light, intended to be a "replacement" in case a light is damaged or stolen, but the whole kit is available, too.
That's a pretty neat idea. Definitely post pics of the results when you're done!
Thanks for the info
Design, construction, materials, pattern, depth, and they won't rust into a ****pile. The only thing that's changed for KC since the 70's/80's is that they're more cheaply made. KC is originally out of Arizona, PIAA is based in Oregon, so they're both American companies. It's just that one makes top notch products and the other can be found on the shelves in Walmart and Autozone. And at only $114 per 520 ATP Extreme, that's a great deal for a fantastic light.
I picked up these 8" bosch lights that I am currently doing nothing with. I just need the time or energy to make the project happen. I 1/2 heartedly put them up for sale as I could use the money towards a tune. These were made for using on big tractors out in the fields I believe. I will have to look into the beam pattern again. Honestly I'm a little scared that I will get pissed at all the idiots out here that forget to turn off their highbeams and shower them with so much light that I send them off the road.
for those that need a front plate... I just placed mine between the bars so it showed out front.... Legal ? dunno - but never got stopped in 3 or 4 years before I traded...
https://www.ford-trucks.com/user_gal...=25205&width=0
but I've eyed those led bars too... the step son has the front of his raptor draped in the rigid bar and double spots where his fogs would be.... the oncoming traffic BEST not flash him, or he might then turn on his LIGHTS !
now - how do I mount them without detracting from the nice Platinum grill ?
maybe below the bottom grill member ?
and put some rope lights behid the chromed crosshatched grill members?
LMAO. Side mirrors. Was thinking drilling holes in the upright supports BUT not no more lol.
Like the tube brackets u posted. How can I post a pic of my ranch hand for input on placement.
Also do I aim these lights 1 1/2" low from center of beam at 25' away, like they recommend ????. Or what will give me the best outcome ?
I'm gonna use two of the PIAA's u recommend
Also if anyone has any instructions on installing 05 upfitters in a pre 05 truck it would be greatly appreciated i know the wiring stuff but not the fuse locations...
Here is a pic of the Bulb inside the light housing. I took these ones with a 3000k light.
I secured the bulb by using super glue and bending the tabs that hold the H3 bulb out. This allowed the bulb would sit in the opening then i bent the tabs back so that they would hold the bulb in place while the glue dried. After the glue dried i filled the surrounding area with silicone and used the plastic washer that holds the HID bulb in its case to press it down and fill in the gaps (also makes it look prettier lol).
I then drilled a hold in the middle of the outer plastic housing that the light itself mounts too. Honestly forget the size right now but i believe it is a 1" hole, i will check this once i find a ruler.
Here is the finished product after the light has been seated back in its plastic outer housing and the grommet has been put in. i plan to drill 4 holes in the header panel to mount these and i will mount the ballasts probably on the back side of the panel or bottom not quite sure yet.
Any help is appreciated.
Sorry to hijack the thread. Just frustrated here.
It's a 2010 F-350 Utility body Gasser.
Thanks,
Bob
Pittsburgh, PA
