LED Light Conversion
Old Apr 26, 2013 | 06:39 PM
parkland's Avatar
parkland
Originally Posted by fmc400
Perhaps I was not clear the first time. My response to this thread has not been in the context of newer vehicles, or retro-fit kits. The question, as I interpreted it, was "where do I tap into the resistor that controls turn signal timing." My answer remains the same - there is no such resistor on these trucks. That's these trucks, 1973-1979 Ford pickups (and many others), not new vehicles, not LED kits bought on eBay.
You're answer does not help the problem, of installing LED lights.
The answer, is simple, and not complex in any way.
To install LED lights in ANY vehicle, you use a load resistor, that usually comes with, or is sold by the same place that sells the LED lights.
That applies to 1973-1979 trucks, it applies to 2013 trucks, and everything in between.
Old Apr 26, 2013 | 08:32 PM
fmc400's Avatar
fmc400
MSEE
I don't think I can make this any more clear. The OP asked what wire color corresponds to a "timing resistor" on these trucks. I responded to that question with a very direct answer: there is no such thing on these trucks. I then went on to say that an electronic flasher takes load current completely out of the picture, which I see as a much easier alternative to a shunt resistor. How are these answers not helpful?
The answer, is simple, and not complex in any way. To install LED lights in ANY vehicle, you use a load resistor, that usually comes with, or is sold by the same place that sells the LED lights.
You do realize that not all vehicles through 2013 use thermal flashers, correct? Plenty of modern vehicles use electronic flashers. Are you sure you're not confusing series resistors, which DO need to be used with any LED used in a 12-volt application, with shunt (load) resistors that are only necessary to "fool" a thermal flasher?
Current-limiting series resistors DO need to be used with ANY vehicle running LED lights, but for a completely different reason. The only reason one would use a current-dumping shunt or load resistor is to fool a thermal flasher. Electronic flashers have no minimum load requirement; an LED light setup with an electronic flasher requires no load resistor. However, each LED still requires a current-limiting series resistor regardless of the flashing mechanism.
Said another way, there are two options:
1) Use the original thermal flasher, and deal with load resistors, -OR-
2) Use a modern electronic flasher that doesn't care about load current, and be done with it.
I voted for option (2) and made that clear in a previous post. I don't understand how expressing that opinion is not helpful for someone interested in an LED conversion.
Old Apr 27, 2013 | 12:36 AM
parkland's Avatar
parkland
Sorry if I insinuated that you didn't add any useful information, that was not my intent.
However, lots of vehicles have issues with LED conversions, not just vehicles with thermal flashers.
All LED lamps I've ever seen for auto use are built with current limiting resistors, that is not what I was getting at.
The load resistors are popular cause they work.
Some cars even throw warnings up cause it thinks the bulbs are dead.
Old Apr 27, 2013 | 03:36 AM
Aaron-71's Avatar
Aaron-71
Well this thread got ugly very fast.
And to correct my mistake in the OP, I meant to ask about an electronic flasher, not resistors.
I only referred to the word "resistance" in the OP because the installation of the LED lights will change the completed circuit, thus requiring the installation of something foreign into the truck to correct the blink rate of the turn signals.
The "current resistor" was supposed to be "OEM Flasher Unit". Hopefully these old trucks have a flasher unit, cause I'm not even sure that they do.
Clarification was needed, so I'll take the blame on that one. As a suggestion though, communication courses or something might be needed to help those of you who are arguing to manage your tone and writing style better on this forum.... angry writing doesn't do anything for you.
Originally Posted by ranger429
Copied from another post:
Mind if I ask where you got that copied text from? I'd like to grab the link and check out what else was written in the rest of the thread just for reference.
I'm hoping the rest of the thread has pictures.
50 for 18 bucks, not 50 bucks.
I didn't take any prior pictures, or after for that matter, but I know they are LED and they will last a lot longer than a regular 194 bulb. And they are perfectly bright! It made my Peterbilts dash go from blah to holy chit I can see!!
Whooops! Guess I should have paid attention to the price a bit more. For some reason I was paying attention to the "50x" part of the description and mistook it for the price.
Old Apr 27, 2013 | 08:41 AM
fmc400's Avatar
fmc400
MSEE
No worries at all!
That's a great point. It would not be the case for truck in question (or most late-model Fords for that matter), but I have heard of that happening in other applications.
Old Apr 27, 2013 | 09:45 AM
ranger429's Avatar
ranger429
79 Thunder Up Build! - FSB Forums
Old Apr 27, 2013 | 10:06 AM
fmc400's Avatar
fmc400
MSEE
These trucks do have a flasher; if they did not, the turn signals wouldn't flash. The original flasher is a thermal flasher. LEDs do not draw enough current by themselves to actuate the flasher. You can solve this problem by pulling extra current with a shunt resistor, or replacing the thermal flasher with an electronic flasher. This has been the point of my responses.
I'm guessing this is directed at parkland and myself. Spirited debate is a part of any internet forum. At no point were any of my statements based out of anger, and at no point did I sense anger from parkland. And while it took us a couple iterations to get in sync, I don't think we need "communication courses" to fix that. Some of the threads that get started here look like text messages, written by someone with little command of the English language that make no sense at all. You might suggest those folks take classes; compared to most of the banter that gets thrown around here, I felt like the discussion between parkland and myself was relatively legible.
Old Apr 27, 2013 | 10:36 AM
parkland's Avatar
parkland
Hey, it's like were all sitting in the garage BS'ing about this stuff.
Arguments are normal, everyone is never going to agree 100% of the time,
and sometimes computer chatting doesn't always transmit what you are trying to say, the same as if you're face to face.
If we were in my garage, I'd pour you guys a drink, but since it's the internet, heres a pretend one, lol.
Old Apr 27, 2013 | 01:56 PM
Aaron-71's Avatar
Aaron-71
Thanks! Always a big help.
Cool thanks. Glad to know the swap is simple, just like my motorcycle.
No one is ever too old to learn. I'm sure we can all agree that the last thing this forum needs is poor communicators.
Even though your message wasn't meant to be angry, I certainly read into the tone of the message which made it seem angry. Communication courses help communicators to create tone-sensitive messages in any discourse.
I'm not saying we need to be perfect communicators on this forum, but what I am saying is that it wouldn't hurt FTEer's to learn a little more about the theory behind communication. Communication courses are essentially life-long learning courses.
Thanks for the assistance though. I do appreciate your insight and time put in to helping me with my curiosity about these old trucks wiring.
Lol, a virtual beer is as good as a real beer if it comes from FTEer's. Cheers.
Old Apr 27, 2013 | 02:05 PM
fmc400's Avatar
fmc400
MSEE
Right on .
mannermauler
42
Sep 25, 2024 11:35 AM
skyrader
Electrical Systems/Wiring
Aug 20, 2017 04:12 PM
KawiG5
Bronco II
Feb 1, 2007 04:45 PM
rwilimo
Dec 20, 2006 04:44 AM
OnEDGE
1983 - 2012 Ranger & B-Series
Oct 13, 2006 10:42 PM
