Pedal Assemblys
Old Apr 22, 2013 | 11:26 AM
k_brenner's Avatar
k_brenner
Pedal Assemblys
Ive done some lookin around but no one seems to have a straight answer. Can the clutch pedal assembly from a bump (excluding 67) work in a dent?
Old Apr 23, 2013 | 02:11 AM
privateer, eh's Avatar
privateer, eh
I'm opening up my 78's pedal assembly tomorrow to change my pedal system over accept the pedal assembly from a 89. long story. You may have to do the same thing I need to do, remove the dash. Once that's out of the way anything is possible, with a little bit of fabrication. When changing between generations theres usually fabrication involved. Clutch and brake pedals are quite often mounted on the same hangar bracket and theres usually an alignment problem involving the mc and clutch linkage length. Hard to explain without pics, If I remember, I'll take pics and put them in my garage
emeraldcoupe
Jan 23, 2015 03:34 PM
Brad_81Ford
Nov 4, 2011 07:56 PM
camodown
Ford Truck Parts for Sale
Oct 2, 2010 09:00 PM
AWALL
Aug 17, 2008 08:56 PM
