Clutch Pedal Problem
Old Aug 16, 2008 | 05:46 PM
AWALL's Avatar
AWALL
I have a 92 F-250 7.3L Standard Transmission
It has been sitting for a few years at the farm and I just got it running again. Had to replace the brake booster, it would suck to the floor if I didn't removed the vacuum line. Now when I push in the clutch the brake pedal also goes down. This makes things quite interesting while driving. I have seen post about the clutch petal bushing the runs across through the brake pedal, so I got under there and sprayed some silcone, grease, and whatever else I could find trying to free it up. Unfortunately, it didn't work. I suppose I need to replace the bushing, but I can't seem to find one and I was also trying to figure out how to get it out of there? Any suggestions/ideas would be great. Thanks
AWALL
Old Aug 17, 2008 | 01:35 PM
AWALL's Avatar
AWALL
Anyone?
Old Aug 17, 2008 | 02:10 PM
quicklook2's Avatar
quicklook2
these truck do not respond well to sitting around for any length of time.
i will try to see what the service manual says when i can.
looks like you unbolt the clutch pedal and remove it, you have to remove the spring.
i suggest you look in chitons at the illustration, instructions.
looks like what you need.
Old Aug 17, 2008 | 08:11 PM
madpogue's Avatar
madpogue
Did you actually slither down under the dash, and push the clutch pedal with your hands, while observing what contacts what, to see what's catching the brake pedal?
Old Aug 17, 2008 | 08:46 PM
AWALL's Avatar
AWALL
Yeah, I looked under there at the bar that runs across from the clutch through the brake and then out to the clutch master cylinder. I really just wondering if anyone knew how to get the pedals out (if needed) to change the bushings.
Old Aug 17, 2008 | 08:50 PM
EPNCSU2006's Avatar
EPNCSU2006
You have to take out the whole pedal box, and to do that you have to unbolt and collapse the part of the steering column that is in the way. Once you have the pedal box out of the truck, you can pull the cross-shaft lever (mark its position since it is splined, this is your clutch adjustment) and the clutch pedal and cross shaft should come out the clutch side of the pedal box.
Old Aug 17, 2008 | 08:56 PM
quicklook2's Avatar
quicklook2
because it is a little complicated is why i suggest using the illustrations in the manual.
keystoneaz
24
Mar 28, 2023 06:45 PM
milehieagle
Jan 1, 2015 10:05 AM
geoffunkel
Sep 25, 2013 12:07 PM
geoffunkel
Jul 23, 2013 12:32 PM
Idaho Mtn Man
17
Mar 13, 2011 11:51 AM
