Sticky Clutch Pedal
Sticky Clutch Pedal
So, recently I had a squeak in my clutch pedal. I just sprayed the linkages under the dash with WD-40 and it went away (also made the pedal much easier to press). Now I have a new problem. More recently, my clutch pedal hasn't been returning the full way. It gets very close, but then just stops. With a slight kick it will snap back up to the proper location. I've tried WD-40 again, but it didn't help it all that much. Should I try some lithium grease?
I seem to be spraying everywhere. There is one spot where a spring right above the pedal goes into a long cylinder (like the brake pedal does), but I can't see that spot let alone spray it.
cabloom300
01-22-2013 10:51 PM
