ABS question
Old Apr 21, 2013 | 06:56 PM
Yahiko's Avatar
Yahiko
ABS question
My ABS light lit up this last weekend for a short time It went out just as
soon as I looked at it. I checked with the scanner and got the code C1145
C1145 Wheel speed sensor RF input circuit failure
What would be a cause of an intermittent C1145? I think this is the 2nd time
in 6 Mo. But can't be sure on that outer than I have had it come on before.
Could it be as simple as a wet/dirty plug? Or am I going to be doing something
with the unit bearing?
Thanks
Sean
Old Apr 21, 2013 | 07:12 PM
BLADE35's Avatar
BLADE35
Thanks
Sean
I think you could be correct
Only thing I would add is Loose connection somewhere
The tone ring is Part the Axel Shaft isnt it I cant remeber been awhile since I had apart
Old Apr 21, 2013 | 07:19 PM
Yahiko's Avatar
Yahiko
I was just looking at the pinpoint test in the Ford workshop manual and
it looks like bad connection is where I start because it's intermittent.
At least I don't have to deal with the tone ring like on a 2X4.
Anyway I'll unplug it and use some contact cleaner on the plugs, put
a dab of dielectric grease and call it good. Hope that is a fix.
Thanks Benny
Sean
P.S. Next time I am in Twin Falls I have to see if I can take a side trip and say HELLO.
Old Apr 21, 2013 | 07:40 PM
BLADE35's Avatar
BLADE35
Oh ya I used to work in SunValley
Twin falls is about 3hours from Me
Have Family in Twin??
Old Apr 21, 2013 | 07:55 PM
Yahiko's Avatar
Yahiko
Yes,
Mom's family is in Kimberly and Dad's was in Jerome.
Everyone seems to now be in and around Twin Falls now.
I try for ever other year when I can. and I am do this next summer.
Sean
Old Apr 23, 2013 | 06:15 PM
Yahiko's Avatar
Yahiko
Well I took the connection apart and looks like a bit of
corrosion or fuzz on one of the pins. Cleaned it out and
added some dielectric grease and remounted the plug
to the splash guard because it had fallen off also.
Now I will have to wait and see if it comes back.
Sean
Angrywasp
Sep 12, 2017 08:03 PM
broknsmokey
May 7, 2016 01:04 PM
02 Super Duty Guy
Aug 7, 2014 06:29 PM
Brenda Lamka
28
Apr 6, 2014 10:39 PM
darkmage55
1997 - 2003 F150
May 18, 2010 03:03 PM
