Sponsored by: Auxito
ABS Light stays on
Old May 17, 2010 | 07:31 PM
darkmage55's Avatar
darkmage55
ABS Light stays on
My abs ligh stays on. When i start my truck if i keep my foot on the brake it doesnt come on until i take my foot off the brake. Otherwise, its constantly on. Any suggestions?
Old May 17, 2010 | 08:36 PM
Ron W.'s Avatar
Ron W.
Got a code reader that will read ABS ?
Checked fluid level? do the stoplights work?
Old May 17, 2010 | 10:22 PM
steve(ill)'s Avatar
steve(ill)
when you start the truck, the computer checks to see that you have a complete circuit to all the speed pickups. The light will come on if it sees no complete circuit in one pickup. If the light stays out, then you put the truck in gear and start moving, at 5-10 MPH a second check is made to see if you are getting a moving signal. If the light comes on, one sensor is not working or reading the counts....... it is alos possible the problem is in the ABS module or computer, but less likely.
Old May 18, 2010 | 11:38 AM
Fordracer2001's Avatar
Fordracer2001
Is it making any noises in the grinding/howling noises in the front end, sometimes when a wheel bearing is going out the light will come on if there is a lot of play in it. Happened on my truck when both front bearings went out, also disconnect the plug for the abs going to the wheel bearing and see if any water got into it, use to run into that a lot when i worked at a shop, it only takes a little bit of water to short out the circuit.
Other than that an abs code reader is going to be the fastest route to the cause
Josh
Old May 18, 2010 | 03:03 PM
darkmage55's Avatar
darkmage55
Naw its not really howling, only from my tires. Ill check the connector to the hub and try to dry it out.
gthbryce
May 19, 2009 12:24 PM
tim nick
1997 - 2003 F150
Mar 25, 2009 07:48 PM
Texas Charlie
Jul 17, 2008 07:57 PM
samahi72
Feb 23, 2006 03:50 PM
bronco502
1978 - 1996 Big Bronco
Mar 12, 2004 11:00 PM
